Chirping sound - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 8 Old 05-23-2013, 01:45 AM Thread Starter
Chirping sound
I have 2007 wee strom with about 20 k on it .i started to hear an intermittent chirp now and then around the instrument panel.Tonight There was a couple of loud squalls then quiet. I am thinking its the cable for the Tac or speedometer . Anyone have a suggestion on how I can lube the cable if thats the problem or would it have to be replaced ..... Thanks
ak bike is offline
post #2 of 8 Old 05-23-2013, 06:28 AM
DougP's Avatar
Send a message via Skype™ to DougP
RE: Chirping Sound
Our bikes have no "cable" for the speedo. It is a wire. The chirp is from the sending unit. Repack it with wheel bearing grease. That means fill it up with the stuff. Chirping noise will be gone. Thank you GW.
DL650K7
OEM Center Stand, Givi E460, E41 Cases, SW-Motech QR racks, Russell Day Long, GIVI windshield, BarkBusters, Madstad, Aprilia Mirrors, Touratech GPS holder
DougP is offline
post #3 of 8 Old 05-23-2013, 08:09 AM
I think it's amazing that people invariably call the noise from a dry sensor a chirp. Anyhow, the sensor has an inner and outer part. Separate the two and grease the interface.
post #4 of 8 Old 05-23-2013, 09:59 AM
That is what came to mind when I first heard it on mine. Just like the little birds that start waking me up as early as 2:00 AM!!
06 V-Strom DL650
John V Strom, Jr. is online now
post #5 of 8 Old 05-23-2013, 11:54 AM
It takes just a very light film of grease on parts that aren't supposed to touch but sometimes do touch--thus the intermittent noise.
post #6 of 8 Old 05-23-2013, 12:58 PM Thread Starter
Thanks for the advise on the speedometer noise .not positive what to take apart to lube it , maybe you tube ?.
ak bike is offline
post #7 of 8 Old 05-23-2013, 01:10 PM
V-Tom's Avatar
What isn't being said is that the sending unit is on the front wheel assembly. From a rider's point of view it is in line with the dash so it sounds like the sound comes from there. If you keep riding without lubing it the chirping sound will gradually get worse.
If you look at the left side of the front wheel axle you will see it sitting there with the wires running out of it. You need to take off the front wheel to get to the unit as the axle runs through it. The sender splits in half and needs a good shot of grease. You also need to make sure you put it on correctly so that it doesn't spin. Other more technical minded members can tell you of the size of the hex head needed and give other tips but it is pretty easy to do (if you have a centerstand.)
..Tom
2015 DL1000 New July 2015 175,000+ km, 108,500+ miles.
SMIDSY detailed report.
V-Tom is online now
post #8 of 8 Old 05-24-2013, 01:14 AM Thread Starter
Lubed the sender per your guys input.Chirps gone , again thanks , and appreciate the detail Tom.
ak bike is offline
