Poll regarding loose rotor magnets. - Page 6 - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
Information Vault A place to post polls about members and their bikes as well as published information relevant to V-Stroms, for example, tech reports, dyno charts, brochures, articles etc.
View Poll Results: Select the proper option at the top of the if you have found loose alternator magnets
2002 DL1000 1 1.45%
2003 or 2004 DL1000 22 31.88%
2005 or 2006 DL1000 20 28.99%
2007 or 2008 DL1000 16 23.19%
2009 or later DL1000 2 2.90%
2004 or 2005 DL650 0 0%
2006 or 2007 DL650 2 2.90%
2008 or 2009 DL650 4 5.80%
2010 or later DL650 2 2.90%
Multiple Choice Poll. Voters: 69. You may not vote on this poll
 1Likes
post #51 of 55 Old 01-11-2015, 01:25 PM
Originally Posted by realshelby View Post
Stators fail because the insulation around the windings fails and causes a short. The magnets are held by the rotor and if they were to "lift" they would contact the outer diameter of the stator. Which does not have wires on it. Still, not a good thing.
Speaking for the DL 1000 only, I am seeing a rather high percentage of stator failures that also include loose magnets. I can't say "most" at this time, but it is a considerable percentage.
Add me to the casualty list. First and last Suzuki: O5 V with 29k mi, loose magnets and bad rotor. Found 5 loose magnets, one broken, one smashed into grounds. Using about 1 qt oil / 1.5k miles, undoubtedly related. Is Homer Simoson still on.Suzi's engineering staff?
Just hoping to get this POS in salable running condition (with full disclosure) with minimal blood loss, thenshop for a Honda. Anyone with two intact magnets or a decent salvage rotor for sale? Much appreciated.
Phoenetic is offline
post #52 of 55 Old 02-02-2015, 04:51 PM
trapperdog's Avatar
As per my post on the charging problem thread:
Just found one magnet loose and shifted along with one fried pole on the stator. Changes in the on board volt meter readings helped in early detection.
'09 VEE
'07 HD SEUC
'09 ST1300P
'06 ST1300
trapperdog is online now
post #53 of 55 Old 04-04-2015, 02:39 PM
While I've got it on my mind and I took the photos, I'll post them here, as this seems to be where I ended up when searching this problem.
The magnet dimensions for an '07 DL1000.
60 mm end to end (not taking into account the curvature)
33 mm wide
8 mm thick
I have four loose ones available, marked with the correct side facing "out" so the polarity matches up upon re-installation.
Hope this helps someone out.
Villu107 likes this.
brokeagain is offline
post #54 of 55 Old 09-30-2015, 11:46 AM
Added another 2004 to the list. 4 out of 6 magnets were shifted. One coil was burned and my R/R is trash. I've also owned this bike for three weeks.
MyNameisWoody is offline
post #55 of 55 Old 05-01-2018, 04:28 AM
I need one magnet.
Please write me if you can help me out. viljar.raudauk(štt)gmail.com
Last week I was planning to ride TET Latvia but my DL lost his magnet.
transeurotrail-Latvia
33 mm wide
8 mm thick
Villu107 is offline
