Poll regarding loose rotor magnets. - Page 3 - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
Information Vault A place to post polls about members and their bikes as well as published information relevant to V-Stroms, for example, tech reports, dyno charts, brochures, articles etc.
View Poll Results: Select the proper option at the top of the if you have found loose alternator magnets
2002 DL1000 1 1.45%
2003 or 2004 DL1000 22 31.88%
2005 or 2006 DL1000 20 28.99%
2007 or 2008 DL1000 16 23.19%
2009 or later DL1000 2 2.90%
2004 or 2005 DL650 0 0%
2006 or 2007 DL650 2 2.90%
2008 or 2009 DL650 4 5.80%
2010 or later DL650 2 2.90%
Multiple Choice Poll. Voters: 69. You may not vote on this poll
 1Likes
post #21 of 55 Old 03-18-2014, 07:41 PM
Exactly what I needed. Thanks Terry!
Warped
Mesa - hot as hell - Arizona
WarpedRotor is offline
post #22 of 55 Old 04-10-2014, 08:34 PM
loose magnets
I have a 2006 1000 with 71,000 miles and recently have had intermintent charging problems, the rotor magnets have moved and some are broken. I ordered a new rotor and stator just to make sure everything is good. Should I JB weld the magnets on the new rotor before it is installed? or has Suzuki used a better adhesive on the new one?
litespeed602 is offline
post #23 of 55 Old 05-02-2014, 03:40 PM
2006 dl1000
If you get to it...
and you can't do it...
then there you jolly-well are,
aren't you?
---Lord Buckley---
NewSuz is offline
post #24 of 55 Old 05-06-2014, 03:55 AM
2006 Wee, 2008 Wee, 2 x 2008 Vee, 2008 Wee and 2010 Wee again. Never had this problem.
Rick123 is offline
post #25 of 55 Old 05-15-2014, 08:26 PM
me too!
'07 1000 with only 29k km on it. Took cover off today and found loose magnet. Annoying!
Paul C is offline
post #26 of 55 Old 05-21-2014, 09:00 AM
Which JB Weld are people using ?
10 DL1000
08 DR650SE (sold)
03 SV1000 nekked (sold)
01 Cagiva Raptor 1000 (sold)
BurnieM is offline
post #27 of 55 Old 05-21-2014, 09:20 AM Thread Starter
The standard, slow setting stuff. J-B Weld | Original Cold Weld Formula Steel Reinforced Epoxy
post #28 of 55 Old 05-24-2014, 05:06 PM
vegashotwheeler's Avatar
Send a message via AIM to vegashotwheeler
Tore my '06 1000 with 36K miles apart today to inspect the mag's and stator.
All looks good for me but went on and did some preventative JB Weld around the mags to make sure they don't move.
By the way is the gasket reusable?
Mike
2007 Blue DL650 V-Strom - running out of farkle's to do so bought the VEE
2006 SILVER DL1000 - Running out of Farkles also!!!
2017 EX300 Kawasaki Ninja
Las Vegas, NV
vegashotwheeler is offline
post #29 of 55 Old 05-24-2014, 05:16 PM Thread Starter
If the gasket comes off in on piece it is reusable. If some sticks to one side and some to the other side, it needs to be replaced. the longer it is on, the more likely you'll need a new one.
post #30 of 55 Old 05-24-2014, 05:33 PM
Thank you sir!
It came of in one piece and looked great that's why I asked.
But got a new one in package sitting here for the next time I guess
Mike
Las Vegas, NV
