Poll regarding loose rotor magnets. - Page 2 - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
Information Vault A place to post polls about members and their bikes as well as published information relevant to V-Stroms, for example, tech reports, dyno charts, brochures, articles etc.
View Poll Results: Select the proper option at the top of the if you have found loose alternator magnets
2002 DL1000 1 1.45%
2003 or 2004 DL1000 22 31.88%
2005 or 2006 DL1000 20 28.99%
2007 or 2008 DL1000 16 23.19%
2009 or later DL1000 2 2.90%
2004 or 2005 DL650 0 0%
2006 or 2007 DL650 2 2.90%
2008 or 2009 DL650 4 5.80%
2010 or later DL650 2 2.90%
Multiple Choice Poll. Voters: 69. You may not vote on this poll
 1Likes
post #11 of 55 Old 03-10-2013, 12:59 PM
James, I agree with Greywolf on using the standard slow cure JB Weld. I researched it very carefully when looking for an adhesive to hold the magnet in place on the Final Drive Minders I make for Beemers. The magnet company actually recommends it for this and the specs from JB Weld give it well over 400 degrees of temperature rating. It is rated for the oil bath environment as well.
If I were doing mine I think I might scuff the rotor surface with some 400-600 grit paper and clean very well with solvent. It appeared on mine that the adhesive the factory used came loose from the rotor surface, I think scuffing the surface may help keep that from happening again.
realshelby is online now
post #12 of 55 Old 03-10-2013, 01:12 PM
sempervee's Avatar
You left out a box for " no issues or problems"
Riding since 1973
If Evolution is outlawed... Only outlaws will Evolve.
* 2012 V I C T O R Y Cross Country Tour
2007 1000 " VroomHilda"
2007 Moto Guzzi 1200 Norge - La Dolce Vita
sempervee is offline
post #13 of 55 Old 03-10-2013, 01:18 PM Thread Starter
I tried that with other issues. It doesn't work. The numbers of "no issue" people checking are so under-represented the info is useless.
post #14 of 55 Old 03-10-2013, 01:19 PM
I think it is expected that people with no applicable issues just won't answer, leaving one less category to deal with from a statistical point of view. I suppose that could have been make a little clearer in the original post, though.
G26
Ghost 26 is offline
post #15 of 55 Old 03-10-2013, 04:22 PM
There have been a number of reports of loose magnets on alternator rotors. This is an attempt to see how many and on what bikes.
Great idea on the poll GW, had completed overlooked it.
06 DL1000
2007 Royal Star Tour Deluxe
Illinois is offline
post #16 of 55 Old 03-12-2013, 09:25 PM
Well, dang. I shoulda checked back here before proceeding.
Anyway, too late now. I did the repair Sunday evening. Took my time, adhering one magnet at a time. Made a fairly tidy job of it. Just buttoned it all up again yesterday.
Am reading 13.4-ish across the battery terminals at idle; it increases to about 13.8 at around 4000 RPM.
James
JET_V-Strom is offline
post #17 of 55 Old 03-23-2013, 05:40 AM
Laava's Avatar
Is there any kind of noise from the stator and rotor when this condition is present? Like a rattle or tappety noise?
L4 DL1000 Black Strom No3
Laava is offline
post #18 of 55 Old 04-03-2013, 04:11 PM
No noise that I heard. I suppose that those that had a magnet hit the stator might have had a bit of noise from that. But submerged behind all that metal and with oil on it there may not have been much that could have been heard.
Anyone running a Vee with any miles or some age needs to be running a voltage meter that they can easily see!
post #19 of 55 Old 03-18-2014, 01:01 PM
Can someone post pics of good versus bad/wobbly magnets? I am a crayola sort of dude and hi resolution pictures help me out quite a bit.
Thank you.
Warped
Mesa - hot as hell - Arizona
WarpedRotor is offline
post #20 of 55 Old 03-18-2014, 01:12 PM
Typical "loose" magnets as they were found:
This is a brand new rotor for comparison:
