A poll on charging system problems. Yes/No and what bike? - Page 3 - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
Information Vault A place to post polls about members and their bikes as well as published information relevant to V-Stroms, for example, tech reports, dyno charts, brochures, articles etc.
View Poll Results: Please check as many answers as apply to you.
I had a charging system problem on a 2002 DL1000 9 1.52%
I had a charging system problem on a 2003 - 2012 DL1000 82 13.83%
I had a charging system problem on a 2004-2007 DL650 28 4.72%
I had a charging system problem on a 2008 - 2011 DL650 75 12.65%
I had a charging system problem on a 2012 - 2016 DL650 48 8.09%
I had a charging system problem on a 2014 - 2016 DL1000 1 0.17%
I had a charging system problem on a 2017 or later DL650 0 0%
I had a charging system problem on a 2017 or later DL1000 0 0%
Multiple Choice Poll. Voters: 593. You may not vote on this poll
 8Likes
post #21 of 217 Old 07-28-2010, 11:32 AM Thread Starter
Bump to keep the poll active. People who have not had charging problems are needed to make a selection also.
post #22 of 217 Old 07-30-2010, 08:38 AM
tjungman01's Avatar
No charging problems, but I have no accessories except a cigarette socket to power GPS and charge cell phone.
Tim
2008 DL650 - Flat Black
tjungman01 is offline
post #23 of 217 Old 07-30-2010, 06:01 PM
Just to add my experience. I run few accessories in the summer beside a GPS, but winter I'll run Heated gloves, jacket, pants, socks and a gps. I'll modulate it all with my heat trollers, or I'll unplug a headlight and run them all pretty much wide open.
2007 DL650A, with 26,000 miles on it.
Gramps is offline
post #24 of 217 Old 07-30-2010, 07:23 PM
randyo's Avatar
I had a charging system problem on a 2002 DL1000 1 2.44%
I had a charging system problem on a 2003 or later DL1000 4 9.76%
I had a charging system problem on a 2004-2007 DL650 1 2.44%
I had a charging system problem on a 2008 or later DL650 2 4.88%
I had no charging system problems on a 2002 DL1000 0 0%
I had no charging system problems on a 2003 or later DL1000 8 19.51%
I had no charging system problems on a 2004-2007 DL650 17 41.46%
I had no charging system problems on a 2008 or later DL650 10 24.39%
Current polling, throwing out the 02 Vee cause only 1 respondent isn't a big enuf stastistical sample:beatnik:
03 or later Vees have the highest failure rate at 33%
08 or later Wees have the second highest failure rate at 17%
04-07 Wees have a 5.5% failure rate
could it be the larger capacity more agressively wound stators are more susceptable to failure? we know from many reports that the aftermarket electrosport stators certainly are
we need more people to respond
RandyO
IBA# 9560
07 Strom 1k (8x,xxx miles)
99 SV650 (135,006 miles)
82 XV920R
A man with a gun is a citizen
www.gbhsurvey.com
randyo is offline
post #25 of 217 Old 07-30-2010, 08:23 PM Thread Starter
I suspected the higher capacity systems might have a higher failure rate. That's why I set up the poll to keep them separate. We need more responses for sure to get a more accurate sampling. Other polls got thousands of responses but they took a while.
TassieTourer likes this.
post #26 of 217 Old 08-02-2010, 11:26 AM
henerythe8th's Avatar
The poll thread's not likely the right place, but...
It's looking like ANOTHER R/R failure is occurring on my '03!
Time for the mofset, or is it mosfet? upgrade I suppose.
Anyone have a preferred source?
2011 MG Stelvio
henerythe8th is offline
post #27 of 217 Old 08-02-2010, 12:23 PM Thread Starter
Brendan wrote, "I set up this forum as a place to store all important information about V-Stroms."
I think this qualifies. Two sticky posts are a poll on owner's age and MPG reports. Ebay is a good source for cheap used ones. I got mine new from http://roadstercycle.com/Universal%2...%20upgrade.htm
Eastern Beaver has hook up stuff. http://www.easternbeaver.com/Main/El...onnectors.html
post #28 of 217 Old 08-02-2010, 10:44 PM
Originally Posted by Gramps View Post
Are you sure that the Voltage regulator is the shunt type? I was under the impression that it was more of a switch. Like a warm n safe or gerbings thermostat. On for a little bit then off for a little bit etc.. The more load the longer it's on.
Shunt, it's a three phase full bridge with SCR's in one half, voltage gets too high and the SCR's get switched on and shorts the stator.
It's not only a shunt, it's a butt ugly one.
If I had a time machine the "inventor" of that is probably the one person in history I'd go back and whack .
Pete
PeteW is offline
post #29 of 217 Old 08-03-2010, 06:51 AM
To date, I've had no problems on my '09 DL650. However, it only has 8K miles on it. I have several electrical accessories -- Rostra CC, heated grips, heated jacket, GPS & Mix-It2, 3W LED running lights -- but I monitor the battery voltage with a Datel Meter and cutout one of the headlights if I think I'm close to the alternator's capability. I also use LED tail/brake lights to reduce the normal wattage use.
'12 Guzzi Stelvio NTX
'09 DL650 ABS (Sold)
Chuck in Indiana is offline
post #30 of 217 Old 08-03-2010, 12:50 PM Thread Starter
The sample size is growing but more feedback is needed. The age poll has over 2000 respondents. Even those who have had no problem are statistically important so it's best if everybody votes.
