A poll on charging system problems. Yes/No and what bike? - Page 22 - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
Information Vault A place to post polls about members and their bikes as well as published information relevant to V-Stroms, for example, tech reports, dyno charts, brochures, articles etc.
View Poll Results: Please check as many answers as apply to you.
I had a charging system problem on a 2002 DL1000 9 1.52%
I had a charging system problem on a 2003 - 2012 DL1000 82 13.83%
I had a charging system problem on a 2004-2007 DL650 28 4.72%
I had a charging system problem on a 2008 - 2011 DL650 75 12.65%
I had a charging system problem on a 2012 - 2016 DL650 48 8.09%
I had a charging system problem on a 2014 - 2016 DL1000 1 0.17%
I had a charging system problem on a 2017 or later DL650 0 0%
I had a charging system problem on a 2017 or later DL1000 0 0%
Multiple Choice Poll. Voters: 593. You may not vote on this poll
 8Likes
post #211 of 217 Old 07-19-2016, 10:54 PM
Originally Posted by H.D.30-06 View Post
2008 dl 650. Bought the bike in 2014 with about 45,000 miles on it . At about 48,000 the stator went out . I had the stator rewound by Rick's Electrics. replaced the R/R with a series type . I also wired the out of the R/R to the battery on the advice of a mechanic/ friend. This worked well for just over 2 years. Now I'm having charging system problems again. Battery won't take a charge . But I'm sure that's not the cause of the problem.
I meant to say stator not state.
H.D.30-06 is offline
post #212 of 217 Old 07-19-2016, 11:21 PM
Sagebrush's Avatar
Always use OEM stators, the other stuff is crap usually. The aftermarket ones are short lived IMO. I've tried the electrosport crap myself, much rather buy a used one off eBay and roll the dice than that cheap junk.
Sagebrush is offline
post #213 of 217 Old 07-19-2016, 11:48 PM
Not sure if the stator was the original or not. If it's bad again this time I'll definitely go with OEM. Thanks.
post #214 of 217 Old 11-20-2016, 04:38 PM
I was out on a ride when my speedo stopped working and the engine started running rough. After nursing it home, I checked this site and found my problem. Bad stator and a few loose magnets on the rotor. I have two led fog lights and grip heaters. Time for JB Weld and a new oem stator.
Thanks for all of posts with all the expert advise and observations here!
PNWEric is offline
post #215 of 217 Old 01-22-2017, 09:25 PM
teevee's Avatar
to make the numbers more meaningful, there should be options for those not having had a problem. the poll only shows those who have had out of how many?????
'08 DR650, '07 DL1000
teevee is offline
post #216 of 217 Old 01-22-2017, 10:13 PM Thread Starter
It used to have that but I removed it to allow more bike choices. The no problems vote was totally meaningless. People without problems didn't vote. Look at the poll on what bike is owned posted in the same forum. Fewer than 1000 people participated so far even though I have a link to there in my sig. This site has 46,561 members as I write this.
Big B likes this.
post #217 of 217 Old 11-11-2017, 08:38 PM
boroboy's Avatar
Stator problem before recall.
boroboy is offline
