Valve clearance adjustment poll for those who have done it or had it done - Page 2 - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
Information Vault A place to post polls about members and their bikes as well as published information relevant to V-Stroms, for example, tech reports, dyno charts, brochures, articles etc.
View Poll Results: If you have done at least one valve clearance check or had one done, please answer
I have a 650 and have gone through 3 or more valve clearance checks with no adjustments required 21 3.18%
I have a 650 and have gone through 2 valve clearance checks with no adjustments required 49 7.41%
I have a 650 and have gone through 1 valve clearance checks with no adjustments required 243 36.76%
I have a 650 and have needed a valve clearance adjustment at one check 129 19.52%
I have a 650 and have needed a valve clearance adjustment at more than one check 14 2.12%
I have a 1000 and have gone through 3 or more valve clearance checks with no adjustments required 6 0.91%
I have a 1000 and have gone through 2 valve clearance checks with no adjustments required 14 2.12%
I have a 1000 and have gone through 1 valve clearance checks with no adjustments required 56 8.47%
I have a 1000 and have needed a valve clearance adjustment at one check 134 20.27%
I have a 1000 and have needed a valve clearance adjustment at more than one check 14 2.12%
Multiple Choice Poll. Voters: 661. You may not vote on this poll
 3Likes
post #11 of 163 Old 08-08-2009, 11:39 AM
TheTwins's Avatar
For what its worth:
On both my initial (11,000 miles) and second (20,000 miles) valve clearance inspection, the clearance checks resulted in the same values....both intake & exhaust, on both cylinders, close to the tight end of the spec. Not out of spec, but on the tight end.
The point is that the values did not change from the initial to the second inspection. I'm very curious to see what they read at the third inspection.
TheTwins is offline
post #12 of 163 Old 08-08-2009, 11:49 AM Thread Starter
I had the same experience. Most of mine are at the tight half of the spec. The only change using a go/no go method was one exhaust valve on the third inspection that changed less than .001" tighter but still nearer the middle than the lower end of the spec. The tightest valve was a rear intake that cleared .004" but not .005". It has been like that through three checks now.
post #13 of 163 Old 08-08-2009, 03:21 PM
aldntn's Avatar
My guess is that Suzuki builds toward to low end of the spec so the valves will be quiet on the showroom floor; they'll stay in spec through the warranty period as well. If Suzuki built to the high end of the spec: probably no adjustment needed for 100KMi. But, then, that doesn't help make the sale.
09 DL650 ABS
MadStad + stock shield, JCW large topbox, Tuturo chain oiler, Heaterz grips, Suzuki hand guards, GIVI side guards, Aprilia Tuono mirrors, 36l Givi panniers, Richland Rick fork brace, Pipercross Air Filter
http://www.aldntn.bravejournal.com/
aldntn is offline
post #14 of 163 Old 08-09-2009, 03:42 AM
Austin44's Avatar
Low or middle, my K2 was built with precision. I finally did the check at 24,000 miles this June.
Three intakes had 2.75 shims, one had 2.72. Three exhaust had 2.90, one exhaust had 2.88 shim.
I'd call that fussy adjustment at the factory, since retail shims are only available to the nearest .05mm.
The 2.72 intake and 2.88 exhaust were barely at minimum. Both needed 2 sizes down (2.65, 2.80)
to get to high end of spec., the rest just one size down ([email protected], [email protected]).
I figure my K2 is set for life, given the small amount of wear in 24,000 miles including break-in.
I'll check again about 50,000...just to be sure.
Austin
Austin44 is offline
post #15 of 163 Old 08-09-2009, 11:31 AM
thecdn's Avatar
It looks like 32 650s and 19 1000s so far. I'll bet the great majority of bikes out there haven't been checked yet.
My 04 Wee with 21k + miles hasn't been checked yet. I'm not confident I could do it properly and my steering bearings are slowly going so that will be the next major job to be done.
I wish I was as handy mechanically as some of the people on this forum.
Orange 2012 Wee (new in May 2013) - Richland Rich's fork brace and mirror extenders, Givi engine guards and top case, gel grips.
Black 2004 Wee with H&B engine guards, SV Racing Frame and Swing Arm sliders, Superbrace, Givi top case, gel grips
thecdn is offline
post #16 of 163 Old 08-09-2009, 03:20 PM
FireDog45's Avatar
Vee; checked it a little late (around 18K IIRC) all within spec but 1 exhaust near the tight end. Will probably adjust all at the next interval.
Steve
09 GSA
Gone but not forgotten:
Blue 2002 Vee
08 KLR
02 ST1100
99 DR350
FireDog45 is offline
post #17 of 163 Old 08-09-2009, 04:31 PM
garandman's Avatar
So as of this time, 62% of DL650 owners have gone through one or more checks without needing adjustment.
garandman is offline
post #18 of 163 Old 09-07-2009, 09:41 AM
pvwheeler's Avatar
Did my 24000km check yesterday,one intake and one exhaust out of spec,and one more exhaust valve on the bottom end.Adjusted all the exhaust valves while I was in there to 9-10 thou...
hopefully next time will be just a check..
2015 Wee2 EXP "Arya"
2002 DR650 SM "Tormund"
2014 CB500x (wifes)
2018 XT 250 (wifes)
pvwheeler is offline
post #19 of 163 Old 11-01-2009, 12:47 AM
Wamphyri*DFR*'s Avatar
Doing my first adjustment at 18k miles. All valves on the rear cylinder were in the middle of spec. The front had one intake that was .03mm too tight the other was on the tight side of spec at .12mm. Both exhausts were on the tight side as well at .22mm. I went ahead and shims for all four to put them at the upper end of the range. Just waiting on shims to arrive.
The two senior mechanics at my local dealer and are friends so I had them look at my measurements and the shims i was ordering for adjustment and they both said to put 'em at the upper end of the range to be safe and negate the need another adjustment for a loooooooooong time. Couldn't pin them down to mileage estimate though. CYA, I suppose.
I'll be putting in a new air filter, plugs, coolant, chain, sprockets, brake and clutch fluid change as well.
On a side note: When taking off the Givi crash bars I found out that where the bar mounts in the frame below the fuel tank was broken all the way around the weld. Couldn't tell until it was taken off the bike. I'm guessing it was a result of this ride. https://www.stromtrooper.com/showthre...=demagnetizing
I can't complain. They did their job. I'm just going to have it re-welded. Since there are scratches on both sides I'll have 'em both bead blasted and coated with Line-X. Debating on having all the plastics Line-X'ed at the same time.
95 DS80 (son's)
01 KTM Duke II
03 XR50 (joint custody with son)
06 DL1000
07 R6
Wamphyri*DFR* is offline
post #20 of 163 Old 11-01-2009, 02:05 AM
steve68steve
Originally Posted by Wamphyri*DFR* View Post
I can't complain. They did their job. ....
My left side Givi bar looks EXACTLY like that. I just discovered it the last time I rode, and it's never been down. I've had the bars off (to do my valve adjustment, in fact), and they were intact then, so the weld failed just from vibration or temperature cycling since then. They're still installed, but I noticed a shiny area around the weld. Upon further inspection, I noticed I can pull the whole bar away from the flange. $^*#@!
My K5 was like that, too. A little surprising to find such discrete sizes in there when they're not available in the kit.
FWIW, my local dealer had a box with a cubby for each increment in size, and the 270 -280 compartments were overflowing with used shims (they'll take old ones in trade) while others where nearly empty. That suggests to me that most bikes use the same sizes and the manufacturing control is pretty tight.
Upon picking thru, I noticed they were mostly odd sizes, too - not in .05mm increments - suggesting Suzuki expects them to fall in this range and makes more sizes between 270 and 285.
