Will a 2nd generation rear wheel fit on a 1st generation dl650? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
Information Vault A place to post polls about members and their bikes as well as published information relevant to V-Stroms, for example, tech reports, dyno charts, brochures, articles etc.
post #1 of 7 Old 11-01-2018, 03:20 PM Thread Starter
Hey guys, I have a huge bend in my '08 weestrom's rear wheel and found a good deal on a '12 wheel. Is the second generation rear wheel the exact same as the first generation rear wheel?
Thanks
rudolfs001 is offline
post #2 of 7 Old 11-01-2018, 07:47 PM
Stalky Tracker's Avatar
Maybe. There seems to be a difference in part numbers between ABS and non-ABS per Ron Ayers microfiche.
2012 Wee (ABS) - 64111-06G20-019
2008 Wee (ABS) - 64111-06G20-019
2008 Wee (non-ABS) - 64111-06G10-019
2006 Suzuki V-Strom DL650K
1986 Honda Shadow VT700C
1974 Suzuki TM-250
1965 Suzuki 80
Stalky Tracker is offline
post #3 of 7 Old 11-01-2018, 08:31 PM
nvr2old's Avatar
2012 is 1st gen. 2014 is 2nd.
DL-1000 L8
DL-650 K5 red(122K)
09 DRZ400
for the safety of existence.
nvr2old is offline
post #4 of 7 Old 11-01-2018, 09:06 PM
Thatís the liter bike. OP was posting about the 650 in which case 2011 is first gen and 2012 started the second gen
Houstrom46* is offline
post #5 of 7 Old 11-02-2018, 01:48 AM Thread Starter
Interesting, thank you! My rim is non-ABS, and the one I found is ABS. I suspect it shouldn't be an issue.
post #6 of 7 Old 11-30-2018, 02:19 AM
The only difference is an extra ABS ring. I think you are right there shouldn't be any issue.
Rick123 is online now
post #7 of 7 Old 11-30-2018, 04:50 AM
Best guess only. It'll work. As others have said the later bikes have the ABS ring.
The problem is that until someone does it or someone has the two 650's in the garage there's no way to be 100% sure here.
PeteW is online now
Do I really Need To Balance My Rear Wheel ? XLonDL650 V-Strom Service and Maintenance Questions and Discussions 24 07-03-2018 03:36 PM
Rear wheel again dcv DL650A - 2012-2016 8 04-08-2015 03:26 AM
Rear wheel too wide for swingarms tshelfer Maintenance, Tech and Products. 31 08-15-2014 07:06 PM
Checking rear sprocket for wheel alignment Jproaster General V-Strom Discussion 17 05-17-2014 02:53 AM
