Made my own panniers, sort of... - Page 3 - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
Information Vault A place to post polls about members and their bikes as well as published information relevant to V-Stroms, for example, tech reports, dyno charts, brochures, articles etc.
 30Likes
post #21 of 36 Old 03-12-2018, 03:11 AM
Letsgo2up's Avatar
Everybody mounts the bottom of the case to the racks. I mounted the case top to the rack. Made a restraint so the case only opens about 75 deg. Easier to pack into the semi-horizontal bottom and then close the case. Some reusable shopping bags are close enough in size to make good bag liners for the Pelican 1500s.
wingstrom likes this.
'06 DL 1000
'06 Bonneville T100
'01 Honda VTR1000
'09 Kawasaki KLX250
'07 Kawasaki KLR650
Letsgo2up is offline
post #22 of 36 Old 03-12-2018, 10:43 AM
Hola. I mounted a set of Sea Horse boxes on the stock frame too. I used big fender washers under the bolt heads to spread the load.
I was going to make them removable so I bent some strap so the bottom bit hooked over the factory frame.
Since I don't' take them off I cut the handles off so I had a larger flat surface on top.
Sure beats the price of Pelican stuff.
notacop is online now
post #23 of 36 Old 03-12-2018, 03:17 PM
roostabunny's Avatar
Originally Posted by BigBlue505 View Post
I checked out the ones at HFT this weekend - not quite as big as I'd hoped, so I'm comparing the #'s to make sure I'm properly calibrated.
Harbor Freight 3800 Watertight Protective Case - 16-5/16 In.
SKU 63927
Inside Length (in.) 14-15/16 in.
Inside Height (in.) 6-11/16 in.
Inside Width (in.) 10-9/16 in.
IP65 rated
Member's Mark 20 Case -
Inside dimensions: 18.06" x 12.89" x 6.72"
IP55 rated
Here's difference between the two standards -
IP55 Protected from limited dust ingress Protected from low pressure water jets from any direction, limited ingress protection
IP65 Protected from total dust ingress Protected from low pressure water jets from any direction, limited ingress protection
So... internally as mounted, the Sam's club ones are...
- a little over 3" longer, well over 2" taller and similar in depth to the HFT model.
- slightly less dust resistant, if that matters.
- $10 cheaper each ($20 cheaper overall)
Edit:
For reference, a Pelican 1400 is common but smaller in size to the HFT case, but is tested to IP67 (Dust Proof, submersible to 1M for 30 minutes) and costs about $73. ID = 11.81 x 8.87 x 5.18
This Monoprice one is closer in size to the Sam's club one, also IP67, and about $86
DL1000 K6
Purchased in 2017 with following mods already in place:
Regeared (-1F, +1R), PC-V and secondary butterflies removed,
2 Brothers Exhaust, SuperBrace, Spacer mod for rear,
4-piston GSX-R Front brake calipers, braided stainless lines,
aftermarket seat, USB Charging port.
roostabunny is offline
post #24 of 36 Old 03-12-2018, 03:39 PM
SKU 63927
IP65 rated
IP55 rated
Edit: For reference, a Pelican 1400 is similar in size to the HFT case, but is tested to IP67 (Dust Proof, submersible to 1M for 30 minutes) and costs about $73.
I had my MCM Electronics cases that are probably the exact same case as the Sam's Club one and had no problem riding in the rain. No leakage whatsoever. RCnNC has tons of miles on his and I doubt his have leaked either. BTW, you don't need a Sam's Club membership to buy these. Go to your local Sam's and they'll give you a guest pass. Might be 10%, but that's not much when they are so cheap already.
roostabunny likes this.
06 V-Strom DL650
John V Strom, Jr. is offline
post #25 of 36 Old 03-12-2018, 05:02 PM
RCinNC's Avatar
The side cases have never leaked, in spite of the numerous holes in them from the various mounting systems I've installed. I was going to buy a new set for the latest attachment system, but eventually figured "why?", and kept the old ones. As far as using a fender washer inside my cases, I didn't. I used a finish washer which makes for a clean install; plus, the inside of my cases have a 1/4" sheet of ABS on the side that attaches to the bike, to strengthen the case.
My top case did leak once. The rubber gasket had started to deteriorate a little in one of the corners. I fixed it with a piece of nylon rope and some outdoor silicone caulk.
truman3 likes this.
RCinNC is online now
post #26 of 36 Old 03-13-2018, 07:30 PM
BigBlue505's Avatar
I picked these up at a swap meet last year, but never did anything with them (see below). They're old military surplus cases designed for specific tasks, so I had to gut the insides out a bit. These might work on some Givi racks with a little MacGyvering. I'm buying Givi racks because I'll eventually get some small 22 Liter side bags. I'm retired on Social Security so I have to pace my spending. What do you think?
notacop and roostabunny like this.
BigBlue505 is offline
post #27 of 36 Old 03-13-2018, 08:20 PM
Looks good! So that's what the red looks like when it's shiny.
Sent from my VS988 using Tapatalk
DL1000 K6
post #28 of 36 Old 03-13-2018, 09:02 PM
Mr. Kym's Avatar
Originally Posted by PineLaneRider View Post
I got 2 free pelican 1520 cases, but have no racks. I need to find some $100 racks somewhere.
This is a nice setup.
Do you want some photos of my pelicans with the rack attachments. I dont think it would be hard to make the brackets you need for yours.
It isn't "Whoever dies with the most toys wins''
Its "Whoever played with his toys the most wins!!!! "
Mr. Kym is offline
post #29 of 36 Old 03-13-2018, 09:06 PM
Mr. Kym's Avatar
Originally Posted by truman3 View Post
Picked up these cases and found a way to mount them pretty easily. No quick release yet, but I will probably leave them on most of the time.
If there is a sams club near you these cases are on sale now for $19.00 each. Thatís a great deal!
Good Job they look great!!! Is there an O-ring between the case and the door to keep the water out?
Mr. Kym is offline
post #30 of 36 Old 03-13-2018, 10:00 PM Thread Starter
truman3's Avatar
Yes, an O-ring and these things are pretty tight despite the IP55 rating - and super strong. Really a nice case for the money.
So far I have shot them with a pressure washer and only a small droplet got in from a hole that I mistakingly widened with a bad measurement. Other than that, no water inside. Itís also pollen season here and there is no nasty yellow powder inside the cases but plenty on the black paint.
I have also yanked on them with everything Iíve got and almost pulled the bike on me, but the cases didnít budge.
Iím still going to work on a quick release idea but Iím pretty happy with this $50 set up.... for now.
And yes, please post a pic of how you mounted yours.
truman3 is offline
