Made my own panniers, sort of... - Page 2 - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
Information Vault A place to post polls about members and their bikes as well as published information relevant to V-Stroms, for example, tech reports, dyno charts, brochures, articles etc.
 30Likes
post #11 of 36 Old 03-10-2018, 10:12 AM Thread Starter
truman3's Avatar
I compared the case from sams to a pelican I have and the build quality is about even but the molded ribs are different. They appear to be the same as a Nanuk case. Of course sams canít manufacture their own so they get them from somebody. They are very nice and at $19 they are amazing.
truman3 is offline
post #12 of 36 Old 03-10-2018, 12:31 PM
roostabunny's Avatar
For an additional $5-10 a couple of thrift store briefcases that approximately fit the id of the hard cases could give you a packing system modular enough to never need to quick release the hard cases.
Sent from my VS988 using Tapatalk
DL1000 K6
Purchased in 2017 with following mods already in place:
Regeared (-1F, +1R), PC-V and secondary butterflies removed,
2 Brothers Exhaust, SuperBrace, Spacer mod for rear,
4-piston GSX-R Front brake calipers, braided stainless lines,
aftermarket seat, USB Charging port.
roostabunny is offline
post #13 of 36 Old 03-10-2018, 12:46 PM
Some decades ago, I used two plastic coolers as panniers. To mount them on my GT550, I used 1 1/2" strips of aluminum from the hardware store, bent by hand (OK, vise and hammer) and held it together with pop rivets. A hinged top strap and hasp and padlock completed it. I took several trips with them, one more than 2009 miles. They worked fine.
If I can't find a way to mount my 35 year old BagMan saddle bags, I might try the cooler or storage case thing again.
truman3 likes this.
themess is offline
post #14 of 36 Old 03-10-2018, 01:36 PM
PineLaneRider's Avatar
I was all set to go with adventure dry saddlebags that I got really cheap, but the Pelicans fell into my lap. Now I'm torn...
truman3 likes this.
PineLaneRider is offline
post #15 of 36 Old 03-10-2018, 03:10 PM
strominateacup's Avatar
Originally Posted by PineLaneRider View Post
........ but the Pelicans fell into my lap....
There are holes in the sky where the rain gets in,
and the holes are very small, that's why rain is thin.
Spike Milligan.
strominateacup is offline
post #16 of 36 Old 03-10-2018, 04:05 PM
BigBlue505's Avatar
Those bags look good. I've seen something similar at Harbor Freight, but I'll need to get side racks first. I was thinking the Givi racks with 22 liter side cases, but these look much cheaper and about the size I want. I just couldn't snap these on and off as easily as the Givi cases, but I wouldn't have to put the key in every time I opened these bags.
truman3 likes this.
BigBlue505 is offline
post #17 of 36 Old 03-10-2018, 04:11 PM
I saw that Harbor Freight had gotten into those Pelican style cases, are you saying they make one in approximately this size and price range?
That'd be cool since I don't have a Sam's Club membership
DL1000 K6
post #18 of 36 Old 03-10-2018, 10:22 PM
BigBlue505's Avatar
post #19 of 36 Old 03-11-2018, 10:23 PM Thread Starter
truman3's Avatar
Here are more detailed pics, not really a Ďhow toí but how it looked when done. Iím really bad about taking pics during a project to document the process.
My stock rack - Iím sure any one will work.
Removed the Givi contact points and eliminated the use of the latch post but kept the round bottom posts.
Templated the rack bolt locations and drilled the case.
Ran the round bottom posts from inside the case allowing the taper to pull the case close to the rack squeezing the rubber grommets.
Ran a similar sized bolt, washer, (case wall) nylon washer (rack) and nylon lock nut (in that order) from inside the case to the rack.
This system works well, is strong and definitely cheap. But I like the looks and canít find it in me to pay $800 for cases because, I donít ride cross country but cross county - for now at least.
Thanks for the idea of the case inside the case, I think a duffel bag will be fine too but for now there are just some straps, a hat, some gloves and a first aid kit loose in them. Haha.
truman3 is offline
post #20 of 36 Old 03-12-2018, 01:08 AM
Mate, I don't like the look of the top 2 bolts inside the case, looks like they could pull through once you get a bit of weight in it (maybe im over cautious).
A couple of big flat washes (rather the the small washes at the moment) or even better some steel plate with a couple of holes drilled for the bolts however would make it so much stronger
unabletoconnect is offline
