chain tightening issue - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
Information Vault A place to post polls about members and their bikes as well as published information relevant to V-Stroms, for example, tech reports, dyno charts, brochures, articles etc.
 2Likes
  • 1 Post By greywolf
post #1 of 9 Old 09-11-2016, 03:08 PM Thread Starter
wilson1953's Avatar
I have a 2005 VStrom 650. The last two times when tightening the chain, it's become very hard to turn the hex nuts, as if they've reach their maximum tightening point, yet the chain is way too slack. What am I missing and/or ignorant of? Thank you.
Keep the rubber side down.
wilson1953 is offline
post #2 of 9 Old 09-11-2016, 03:16 PM
Did you loosen the axle nut first?
post #3 of 9 Old 09-11-2016, 04:17 PM Thread Starter
wilson1953's Avatar
Yes I have loosened it and removed cotter pin. Thanks.
post #4 of 9 Old 09-11-2016, 04:22 PM
Take off the end blocks if you can and check to see if the adjuster blocks are all the way back. The chain might have been replaced with one having too many links.
Hard miles likes this.
post #5 of 9 Old 09-12-2016, 07:28 AM Thread Starter
wilson1953's Avatar
Both chain and sprocket were replaced about 17K ago and haven't given me any problem until the last couple chain adjustments. I will try your suggestion - thank you for it!
post #6 of 9 Old 09-12-2016, 09:54 AM
Chain length changed in the 2007 model year from 116 links to 118 links and typical aftermarket replacement chains had 120 links as some bike models with 525 chains needed that many. That's why some chains with too many links sometimes get installed.
wilson1953 likes this.
post #7 of 9 Old 09-13-2016, 01:14 PM Thread Starter
wilson1953's Avatar
I very much appreciate you sharing your knowledge and expertise. Much thanks!!
post #8 of 9 Old 09-14-2016, 10:36 PM
A friend and I spent many moments counting links when replacing my chain. We we finally agreed on a count we adjusted the chain and it's been great since.
I adjust the chain at tire replacement intervals and have kept using the same markings as a guide with good results.
notacop is online now
post #9 of 9 Old 10-02-2016, 09:31 AM
chicago's Avatar
yes I count 'em twice before I cut.
14 tooth for me
chicago is offline
