Poll on failed Stator vs. Rotor Magnet Condition - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
Information Vault A place to post polls about members and their bikes as well as published information relevant to V-Stroms, for example, tech reports, dyno charts, brochures, articles etc.
View Poll Results: What was the condition of your rotor magnets when your stator failed?
All magnets appeared equally spaced and glue bond intact 9 47.37%
1 or more magnets were loose and had moved 4 21.05%
1 or more magnets were found shattered 5 26.32%
Did not look for unequal spacing between magnets 1 5.26%
Voters: 19. You may not vote on this poll
post #1 of 13 Old 11-26-2014, 07:12 AM Thread Starter
GVsteves's Avatar
I thought it might be interesting to find out how many of you that experienced a failed stator (burned or otherwise failed) found problems with rotor magnets coexistent with the failure.
I am wondering if possibly loose magnets might actually be a root cause of premature stator failure either because the stator gets hotter with the magnets being shifted or because the loose magnet shifted enough to make contact with the stator and shatter the magnet(s).
I did not vote because my stator did not fail yet but I discovered a loose magnet and began to wonder if I am preempting a failure by proactive magnet repair
2006 DL1000 - Vee for me
2005 DL650 - Wee for my gal
1977 HD XLCH - my past life
GVsteves is offline
post #2 of 13 Old 11-26-2014, 10:02 AM
I wish there was a way to add whether you have a 1000 or a 650. While there are stator failures on 650's, they also outsell the 1000 by a large amount. The 650 doesn't suffer from magnet failures. I think the 1000 stator failure rate is exponentially higher than on the 650 and in that fact I think the magnets might be a part of the cause.
realshelby is offline
post #3 of 13 Old 11-26-2014, 10:45 AM
Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums - View Poll Results shows some magnet problems on 650s though not nearly as many as on Vees.
post #4 of 13 Old 11-27-2014, 06:57 PM
Would still like to see electrical acc. vs non electrics factored. :beatnik:
06 DL1000
2007 Royal Star Tour Deluxe
Illinois is offline
post #5 of 13 Old 11-27-2014, 10:17 PM
wingnut11's Avatar
Burnt out a stator at about 40k miles. All the magnets were right where they were supposed to be. I added some JB weld between them anyway in the hopes that I could avoid a magnet glue failure. That was 1.5-2 years and 25k miles ago. So far no loose magnets or burnt out stators.
wingnut11 is offline
post #6 of 13 Old 12-06-2014, 06:05 PM
BDK generator is another (and very expensive) option.
macop1104 is offline
post #7 of 13 Old 12-31-2014, 12:31 AM
Catastrophic rotor magnet failure
I have an 05 DL1000 V with 29K miles. Battery failed and stator tested low so I ordered a new one from Caltric for $80 (Suzi wants $330!!!). Thought I was good to go until I opened the case and found all but one magnet loose, one fractured and one disintegrated with magnet grinds thruout stator case, probably in crankcase. Yuck. Looks like a major cleanup and repair with who knows what collateral damage.
I don't know if I can get replacement magnets or I have to buy an OEM at extortionist price. Seems like inexcusably poor engineering or worse, planned obsolescence to me. Not happy; wishing I'd bought a Honda.
Any advice (besides buy a Honda)?
Phoenetic is offline
post #8 of 13 Old 12-31-2014, 08:34 PM
wingnut11's Avatar
Well I'm sorry to say you can't buy the magnets separately. So your options are a new one from Suzuki or maybe you get lucky and find a used one. Either way I'd add some extra JB weld on the new rotor to hold the magnets in place.
post #9 of 13 Old 01-01-2015, 10:55 AM Thread Starter
GVsteves's Avatar
used parts source
You could try this guy:
https://www.stromtrooper.com/sale/233...-part-out.html
Few months back another trooper was putting up a "parts" rotor kit which contained some unbroken magnets.
You could try posting in the WTB.
In any case, suggest you follow previous suggestion to fill the gaps between magnets with JB weld even if you decide to go with new rotor.
Stock design is flawed IMO but the JB weld between magnets should be a forever fix if done before the failure can occur.
GVsteves is offline
post #10 of 13 Old 01-01-2015, 11:11 AM Thread Starter
GVsteves's Avatar
You will probably want to pull the clutch side cover and remove the oil screen in there to check for debris. It is right under the clutch basket assembly. Might be hard for a magnet particle to migrate that far without sticking to the rotor body but good insurance to check anyway for the price of a gasket.
GVsteves is offline
