2015 Suzuki GSX-S750 Second Ride Review - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
Home Page News Home Pages news (Mods and Admins post only)
 1Likes
  • 1 Post By Big B
post #1 of 6 Old 06-17-2015, 01:32 PM Thread Starter
Community Manager/Admin
VS Jeff's Avatar
Back in October, Evans Brasfield penned a preview of Suzuki’s then forthcoming GSX-S750. “The middleweight Naked class just got a lot more interesting,” read his kindly subheading. At the beginning of this month (March) Suzuki hosted a press ride of the GXS-S750 in some very non-optimal weather conditions in Austin, Texas. With the first-ride review a literal washout, we withheld reporting our typical evaluation of, and Scorecard for, the Gixxus until we could perform an honest shakedown. Well, that day has arrived, and we can honestly report that Suzuki’s new naked performs almost flawlessly in the most underwhelming way possible.
There’s some minor driveline lash, the suspension is a compromise between comfort and handling with the fork exhibiting some harshness when compressing rapidly, and the seat-to-footpeg ratio becomes tighter as you inch past 5-foot, 9-inches. Otherwise, the Gixxus goes about the business of being a competent motorcycle with the mechanical astuteness and uninspired confidence often associated with Japanese UJMs.
And therein lies the rub. At $7,999 the GSX-S is a nicely styled, comparably priced 750cc wallflower. In the words of one of our readers from the comments section of the First Ride Review, “Not a bad looking or expensive machine, but it’s just not a great value or even a novelty like the Yamahas.” And by “novelty,” we’re assuming Reid is suggesting the inline-Triple and parallel-Twin with crossplane concept engine architecture of the FZ-09 and FZ-07, respectively.
The re-tuned GSX-R750 mill features revised cam profiles and timing, as well as reshaped intake and exhaust tracts to give the naked bike more low- and mid-range power. In true Suzuki fashion, the transmission shifts smooth as butta.
Suzuki has identified Yamaha’s FZ-09 as a competitor for the GSX-S750, and its engine is clearly more potent and exciting than the Suzuki’s. The FZ’s combination of more power and less weight will be difficult for the Gixxus to overcome. A comparison test is in the works.
The Four-Thirds Shootout
With 96.5 horsepower, 52.5 lb.-ft. of torque, and weighing 465 pounds fully fueled, the Gixxus produces less horsepower (8.1 hp) and torque (6.8 lb.-ft.) than the FZ-09 while weighing 49 pounds more.
For its weight, the GSX-S handles urban riding as well as faster-paced canyon carving with equal ability. With 57.1 inches between contact patches, the Gixxus is neither exceptionally long nor short. It doesn’t flit through traffic or a tight set of S-turns with the agility of a hummingbird, but it’s no Dodo bird, either. Leaned over, repeatedly arching through a fast, bumpy sweeper for a photo op, the Gixxus gave no cause for concern as it held a tight line and absorbed the worst of the road imperfections without complaint.
The seating position is comfy with footpeg-to-seat ratio just a little tight for my 5-foot, 11-inch frame – but that keeps cornering clearance acceptable (see image below). The Gixxus seat is wonderfully supportive and comfortable.
Comfort levels for commuting and/or touring duties are first noticed in the rider triangle that features a short reach to the handlebars and enough legroom as to not cramp my 5-foot, 11-inch frame. A little less bend in the knee would be nice, but it’s not really a factor for anyone under six foot. Seat foam, however, is dynamite, perfectly blending comfort and support. You’ll notice an occasional high-frequency buzz from the inline-Four but nothing to really complain about.
Power delivery and EFI tuning are electric-motor-like, with no undue abruptness. Clutch pull is on the stiff side, but the transmission shifts so smoothly there’s not much use for the clutch when up-shifting. So far, our test unit has delivered 37.7 MPG.
No apparent reason for the brakes being as weak as they are. Fork is of the inverted variety, and it keeps the front end in order even when the pace gets hot.
The front brakes on the Gixxus are notably underpowered for a bike with this much sporting potential. It takes a strong pull on the front brake lever to produce quick deceleration. This can probably be easily and affordably rectified with the purchase of some up-spec aftermarket brake pads, but as is, Ducati’s Scrambler Icon with the single front disc exhibited more impressive stopping performance in our Scrambler Slam shootout than do the dual front brakes on this Suzuki.
The Gixxus handles well enough to invite peg scraping, and has enough cornering clearance to keep things exciting.
The true test for the Gixxus is the upcoming shootout with its FZ-09 nemesis and a couple others. We know the Suzuki suffers a performance disadvantage to the Yamaha, but the FZ has issues with too-soft suspension and unrefined ride modes that kept it from being our pick for 2014 Bike of the Year. So, it’s no sure-thing the Yamaha’s going to win, because we know the Suzuki is better suspended and doesn’t suffer the fueling issues of last year’s FZ; updated ECU tuning for 2015 has significantly improved the smoothness of its throttle response. But if you enjoy supporting the underdog, start waving your Suzuki banners.
+ Highs
Comfy, comfy seat
Perfectly average performance
Affordably priced
– Sighs
Underpowered front brakes
Should be lighter
Nothing here to get really excited about
2015 Suzuki GSX-S750 Specs
MSRP $7,999 / $8,149 for the GSX-S750Z
Engine Capacity 749cc
Engine Type 4-stroke, liquid-cooled, DOHC, 4-cylinder
Bore x Stroke 72.0 x 46.0 mm
Compression 12.3: 1
Fuel System EFI
Transmission Close ratio, 6-speed
Final Drive Chain
Frame Steel, twin-spar
Front Suspension Inverted, KYB telescopic fork, preload adjustable
Rear Suspension KYB monoshock, preload adjustable
Front Brakes Twin 310mm discs with dual piston calipers
Rear Brakes Single 240mm disc with single piston caliper
Front Tire 120/70-17
Rear Tire 180/55-17
Seat Height 32.1 in
Wheelbase 57.1 in
Rake/Trail 25°/104 mm
Curb Weight 463 lbs
Fuel Capacity 4.6 gal.
Colors Metallic Matte Black/Metallic Triton Blue/Pearl Glacier White (Z model only)
Read More Here: 2015 Suzuki GSX-S750 Second Ride Review
VS Jeff is offline
post #2 of 6 Old 06-17-2015, 11:03 PM
Administrator
No ABS....no traction control......average brakes.....budget suspension...bike is a total turd compared to the competition.
D.T. likes this.
post #3 of 6 Old 06-18-2015, 09:37 AM
tenny80's Avatar
sounds about the same as the fz-09 actually, isn't that the competition?
also the bike in canada comes standard with abs.
2018 Vstrom 1000
tenny80 is offline
post #4 of 6 Old 06-27-2015, 07:08 PM
D.T.'s Avatar
I really like the looks of the bike! But like was said, kinda disappointing in the performance department.
D.T. is offline
post #5 of 6 Old 09-01-2015, 11:23 AM
Buck83's Avatar
Don't get me wrong I love my Strom, but when it comes to performance bikes (sport) I prefer CBR's all the way.
Still regret selling my '03 954RR :/
Not the most comfortable thing, but fast, fun, maneuver on a dime, and extremely easy to work on.
"I've always been crazy but it's kept me from going insane" ~ Waylon Jennings
Buck83 is offline
post #6 of 6 Old 09-06-2015, 09:56 PM
Kurgan's Avatar
Reading up on the 750, it's relatively disappointing in specs and reality. The 1000, however, from what I've seen/read, Suzuki has redeemed itself.
Jim
Kurgan is offline
You may post attachments
You may edit your posts
