After getting annoyed with the performance of HID Plug n Play bulb into my vstrom assembly for about 1 year i decide to do the project properly. ( Note HID plug and play is a cheap but which works "not to bad" for Vstrom headlight - however it is far from ideal - lots of discussion about HID and reflector housing designed for Halogen bulbs on the net)
I did this about 15 months ago using HID projector retrofit source from here Bi-xenon: Morimoto Mini D2S 2.0 - HID Projectors from The Retrofit Source Inc
( i use Morimoto Mini DS2 projector because it is next to no cutting required for our vstrom headlight assembly and it is reversible, although not readily)
Unfortunately, i did not take pictures whilst disassembling. but the procedure essentially are as follows:
1) Disassemble Headlight assembly;
2) Bake :yikes: headlight housing in Oven at 90c or 200F for 10 minutes
3) Pry open headlights - insert projector and tighten at the back
4) without replacing the front lens refit headlight on the bike and test for horizontalness - on vstrom it requires approx 15 degree anticlockwise adjustment - slight dremelling of housing is required
5) Reassemble and enjoy
I went for an asymmetric look because the light cut-off is too good on a motorbike - it's not a problem for cars - but lean over, i want more stray light above the cut off provided by the normal halogen light to help me see better ( you can see for yourself on the cut off pictures)
Just HID projector light cut-off - note the rainbow colour just above the cutoff - note i did some mods to the cut-off curtain which makes the cut-off line not quite straight - my fault - the light above the cut-off is from reflection from the headlight reflector housing - there is zero stray light with HID projector
for a comparison - my normal headlight on low beam
Finally my combination - gives me evenly lit light output in the foreground without blinding myself and enough light to see further down the road without blinding others.
more pictures of the bike look like - note these pictures are not taken in the dark with blinding camera shots like a lot of people do - my LED DRL and headlights are a lot brighter when seen from further away or at night - but this gives you the best idea of how they look like
