Hello...new rider and new Strom owner here. On about day 5 of riding to work full time, almost got rear-ended in broad daylight. So I went on a mission to improve my braking visibility. My Givi E46 top case already had the E92 lighting installed. But that wasn't enough (and as you can see, one of the bulbs is out and I need to order the replacement lighting panel).
So I called a buddy of mine who makes/sells/installs LED lighting kits for Harley guys. We took the reflector and trim pieces off and installed 96" worth of red LEDs and tapped into the wiring in the box (which is tapped into the brake lights via the EB kit designed for a modulator). I will take a better pic and post...this is my super-excited iPhone pic.
Needless to say, it is quite alarming - which was the goal! Plus it wraps around the side of the case so is uber-visible. First custom farkle for my Strom...yeah!
