Frozen lock - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 3 Old 11-22-2006, 02:38 PM Thread Starter
Frozen lock
This morning it was -4C and I had a nice layer of frost on the seat. When I went to turn the key, it wouldn't budge. I sprayed some WD40 into it but that didn't really help. So, I used my heat gun to loosen it up. Worked like a charm. Luckily is it supposed to be warmer on the way home.
It's been raining like crazy here for the past month and it seems that I've gotten water into a bunch of places I didn't expect. I've got moisture in both my speedo and tach and I found water inside my starter switch housing.
DL650K5 (Silver)
aircav is offline
post #2 of 3 Old 11-22-2006, 02:50 PM
Wee_Willie's Avatar
You didn't mention if it was covered or not...
check this thread.
https://www.stromtrooper.com/forums/s...ead.php?t=7924
[url]http://www.flickr.com/photos/[email protected]/[/url]
IBA#27466
2007 Suzuki GSF1250K7 Bandit - Black of course!
2006 Suzuki DL650K6 - Alaska and back July/Aug 2007
1978 Yamaha SR500E - Frame up restoration in progress
1968 Yamaha DT1 Shorttracker / "Bargain" Craigslist find... yeah, right
Wee_Willie is offline
post #3 of 3 Old 11-22-2006, 03:03 PM
Heavy's Avatar
I was going to say it sounded like a film cannister was in order.
-5C here this AM and my key turned easy!!
Go easy on the WD-40 in the ignition switch, I've heard bad stuff about it.
Good luck with it.
DL1000K6
Heavy is offline
