Quick question - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 9 Old 08-08-2012, 03:26 PM Thread Starter
domromer's Avatar
Quick question
Are the front brake lines routed in front of the fork or behind? I'm changing out my brake lines and I routed them in front as I think the stock lines were. But now I'm doubting myself.
If all you ever do is all you've ever done, then all you'll ever get is all you ever got.
domromer is offline
post #2 of 9 Old 08-08-2012, 03:51 PM
per my bike its behind the forks.
i think its on the backside to avoid being damaged by debris.
[URL=http://www.fuelly.com/driver/biking4jesus/dl1000]Fuelly - 06 Vee - 70k miles[/URL] [URL=http://www.fuelly.com/driver/biking4jesus/cb600f]
Fuelly - 04 Honda 599 - 12k miles[/URL]
biking4jesus is offline
post #3 of 9 Old 08-08-2012, 03:51 PM
Front, and it's one line unless an aftermarket set with a line from the master cylinder to each caliper is used.
post #4 of 9 Old 08-08-2012, 04:21 PM
ah yes, that holder is on the front of the forks. i have an aftermarket SS kit they still go in the front at the top, but the lines pass down and move to the back of the fork near the caliper.
post #5 of 9 Old 08-08-2012, 04:42 PM
I wasn't thinking about the lower runs. They are behind in every situation. Some people adding bar risers will move the top line from front to back to get them to fit.
post #6 of 9 Old 08-08-2012, 05:34 PM Thread Starter
domromer's Avatar
Sent from my phone...there will be spelling errors!
domromer is offline
post #7 of 9 Old 08-08-2012, 05:55 PM Thread Starter
domromer's Avatar
Ok so the way I have it run is that its in front of the tripple tree, in front of the lower fork clamp, and then goes under the lower fork clamp to either caliper. Does this sound right you you guys?
domromer is offline
post #8 of 9 Old 08-08-2012, 06:23 PM
That is the way the original is routed, in front of both triple clamps and curving back under the lower clamp
post #9 of 9 Old 08-08-2012, 06:25 PM Thread Starter
domromer's Avatar
Thanks GW, I was just having a spastic moment. I always plan on paying more attention before I start a project than I never do.
domromer is offline
