Skidplate Material? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 6 Old 08-06-2012, 11:58 PM Thread Starter
Adventure Traveler
Kankujoe's Avatar
Skidplate Material?
I'm trying to decide on a skidplate/bellypan for my new Glee.
The vendor I'm leaning towards offer them in my choice of "steel," "aluminum" or "stainless.". All three choices are powdercoated in black.
Anyone know pros or cons of each? Aluminum & Stainless have about a 30% upcharge. Just trying to make an informed decision.
Joe
2012 DL650-ADV (Black), 2013 DL650-EXP (White), 2013 Honda CRF250L, 2008 Yamaha TW200
IBA #55242, SS1000 x2, BB1500, SS2000, 50CC, National Parks Tour x5 w/ Silver & Gold, 4 Corners & Alaska, 48 plus one, Great Lakes.
Ad-ven-ture: 1. an undertaking involving risk, unforeseeable danger, or unexpected excitement. 2. an exciting or remarkable experience. Trav-ell-er: 1. one who seeks to experience their world. 2. one who seeks to be immersed in other cultures.
Kankujoe is offline
post #2 of 6 Old 08-07-2012, 12:40 AM
CHINOTAKER's Avatar
Aluminium
I will always go for aluminium just for weight.
Just an advice, some skidplates don't get along with centerstands. Just have that in mind is you already have one or you are thinking of getting one.
K9 ABS 650 BLACK
V-Strom: "The bulletproof machine"
[url]http://v-strom123456789.blogspot.com/[/url]
CHINOTAKER is offline
post #3 of 6 Old 08-07-2012, 12:53 AM
I could care less about weight for a skidplate. I went for the steel as it was the strongest and also the cheapest. I know its NOT a true "skidplate" in the sense that you can use it to slide over rocks and logs and whatnot, but if something happens and i end up running over something like that, i want the skidplate that will give me the best chance of protecting the engine. It's not always small rocks that get kicked up, and steel would keep front denting and will simply work for heavier hits. JUST IN CASE.
Alexi
sfalexi is offline
post #4 of 6 Old 08-07-2012, 01:19 AM
bbg.will's Avatar
My aluminum skid plate on my small dual sport protects just fine, and it has taken some heavy hits... Granted, it rides right next to the bike's steel frame, and that supports it when I go sliding over rocks and logs, as opposed to the open expanse that these pans cover on our bikes...
If you are running on the street or dirt roads, or rock covered forest roads, just get aluminum, especially for the weight savings. Whatever road debris gets knocked up towards the belly of your beast, it will more than adequately protect your scooter's delicate bits.
His -[INDENT][/INDENT]'07 Wee-Strom - '07 Kawi KLX250s
Her's -[INDENT][/INDENT]'13 Genuine Buddy 170i Pamploma
bbg.will is offline
post #5 of 6 Old 08-07-2012, 06:38 AM
I have steel skid plate from Yann. The only advantage I could see with aluminum or stainless is that it doesn't rust. I've taken Yann's plate down quiet a few gravel roads and so far the powder coating has held up no scratches that need to be touched up yet.
BornAgain is offline
post #6 of 6 Old 08-07-2012, 06:49 AM
I had a steel plate in the past........never mounted it........weighed 13 lbs.
That's nothing to sneeze about......quite a bit of weight.
www.easternvstromrally.com
mark444 is offline
