Horn Not Working - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 7 Old 07-31-2012, 07:19 PM Thread Starter
wt61443's Avatar
Horn Not Working
Hello all. I have an 07 DL1000 and upon recent findings, my horn doesn't work. I took the bike to get inspected and it wouldn't pass for the horn and rear tire. Needless to say, I don't use the horn that often! I have the tire on order, but I wanted to solve the horn issue. I check the fuses I knew of (under the seat) and all were good. What is the next thing I can do? If this needs to go to the Vee only section, mods please move. I tried the search and a general search on google, but I only came up with adding an aftermarket horn, which at this point I DON'T want to do. The factory is fine with me. Thank you.
wt61443 is offline
post #2 of 7 Old 07-31-2012, 08:17 PM
The first thing to do is to unplug the wires from the horn. Then test the wires for power or apply power from a battery to the horn tabs. You need to figure out whether the problem is the horn or getting power to the horn.
post #3 of 7 Old 07-31-2012, 08:20 PM
trapperdog's Avatar
If you know how to locate the horn behind the radiator, un plug the leads at the horn and put a meter to them while pressing the horn button. (Bike or key on). If you get power, your horn is bad. If there is no power you will need to trace to wires back and check all connections. Don't know if there have been any horn button problems. If your horn is bad, many of us have our old ones we would be willing to give you. Some horns can be re activated by spraying WD40 down the throat. This generally requires horn removal though and I am not sure if it works with the V horn.
Ha, GW beat me to it while I was typing!
'09 VEE
'07 HD SEUC
'09 ST1300P
'06 ST1300
trapperdog is offline
post #4 of 7 Old 07-31-2012, 09:41 PM Thread Starter
wt61443's Avatar
hey thanks guys for the replies. i will get the tools out this weekend sometime and see what I can find out....thanks again.
wt61443 is offline
post #5 of 7 Old 08-06-2012, 02:29 PM Thread Starter
wt61443's Avatar
normally things don't work when they aren't hooked up ....the shop that did my valve check last neglected to hook the wiring back to the dang horn......needless to say, ill will be paying them a visit. thanks guys....now i hope i can return a used horn i purchased online.
wt61443 is offline
post #6 of 7 Old 08-06-2012, 02:37 PM
bassbronco_74's Avatar
Looks like you found your problem. I had the same thing happen, no horn after valve check. I had hooked it back up but didn't push the clip on all the way or the right way. I've learned to start simple then go to the hardest stuff or start cheap.
DL650K7
XL1200N (Sold)
bassbronco_74 is offline
post #7 of 7 Old 08-06-2012, 07:15 PM
tiller4me's Avatar
When the horn works, it doesn't work. I can probably yell louder, and often do.:biggrinjester:
79 GS1000S
97 TL1000S
2005 DRZ400
2005 KDX220R
2007 DLK
2009 KLR650
2007 FJR1300
2007 Honda XR650L
tiller4me is offline
