??? GPS plug - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 13 Old 07-30-2012, 05:43 AM Thread Starter
NMdcporter's Avatar
??? GPS plug
Gang,
Hope I posted in the right spot. Question I have a Nuvi 500 wired and was wondering how do you protect the end of the plug when not in use? I have my 500 mounted to the handle bar with a RAM mount. My plug is a direct connect to the battery (fuse in line). I only put my GPS on when running longer rides, so half the time the plug is just hanging there.
Thanks
Dave
Dave
2008 V-Strom
NMdcporter is offline
post #2 of 13 Old 07-30-2012, 06:13 AM
Voltar's Avatar
Fat rubber band maybe?
Voltar is offline
post #3 of 13 Old 07-30-2012, 08:28 AM
Mud Puddle's Avatar
I just tuck mine up under somthing nearby to keep it from flopping around in the wind and don't worry about it. After 3 years no problems.
09 "Wee"-Strom DL650 (Orange)
99 Harley-Davidson XL1200S
00 Bultaco
73 Bultaco Sherpa-T
Mud Puddle is offline
post #4 of 13 Old 07-30-2012, 08:38 AM
BB63's Avatar
BB63 is offline
post #5 of 13 Old 07-31-2012, 02:25 AM Thread Starter
NMdcporter's Avatar
Thanks for the feedback. My 2720 had a plastic cover for the plug when not in use, so I was a little concerned about this one. It is currently tie-wrapped and just flopping in the wind.
Dave
2008 V-Strom
post #6 of 13 Old 07-31-2012, 09:12 AM
I've had a hard-wired plug on my bike for the two yeras that I've had the bike. When the GPS is not in the mount, it just is loose. Periodically (a couple times a year, I put some dielectric grease in tthe plug.
Ed Foltyn, KQ1R
2009 Suzuki DL650A
efoltyn is offline
post #7 of 13 Old 07-31-2012, 12:43 PM
I tought about using dielectric grease but I was not sure it was a good idea?
Other opinions?
bumper is offline
post #8 of 13 Old 07-31-2012, 01:12 PM
Tollster's Avatar
I always make a point to save those little thread guards that come enclosed in many packages. They are normally red or black rubber/vinyl and come in various sizes. I think they are just dipped at the manufacting place,but slide off easy, they slide over the threads and encase the end of a bolt or all thread, and come in many sizes. I find many uses for them and have one for my alternating headlight sensor that fits like a glove, so I can deactivate if needed.
Check the local hardware store, and look around at some of the items in the hardware section, you may find one attached to something...cheap.
If ya had too, you could use a chunk of rubber hose or tygon tubing,stick a wooden dowel (I would whittle oak branch myself)in the end, or a small bolt,various tygon tubing is available at lowes and home depot.Leave it in your tank bag when not in use.
Tollster is offline
post #9 of 13 Old 07-31-2012, 01:31 PM
Rick505's Avatar
My GPS has a Mini-USB plug so I went to the hardware store and found a vinyl cap that fits a #10 machine screw/bolt. Tight fit but for, I believe 15 cents, does cover the actual metal tip. If you take the cable you may find an even larger one that will cover the entire end of the connector. Auto parts stores generally also sell the same thing in kits to plug off vacuum ports but often in kits. If in doubt ask for a "vinyl Screw Thread Protector Cover". Mine were in those bin things that hold the "specialty" items close to the nuts and bolts.
Rick
Rick505 is offline
post #10 of 13 Old 07-31-2012, 04:29 PM
Been Wondering what do with my plug as well..Hmmm
dbmet is offline
