Getting a bike up on a Maintenance stand - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 11 Old 07-23-2012, 03:50 PM Thread Starter
I'm apparently small and weak because I can't get my Wee up on a maintenance stand by myself. I got the Harbor freight one, and I just couldn't get enough leverage on it to raise the rear end.
For those who have the HF stand (the one with the pads, not the one for spindles) is it difficult for you? (I weigh 165lbs) Are other stands easier?
noexit is offline
post #2 of 11 Old 07-23-2012, 03:55 PM
Jstrom's Avatar
Talking You'll get it...
It's a matter of technique, leverage and practice. Once you get it up the first time every other time is a breeze. Go for it but be carefull.
[SIGPIC][/SIGPIC]K7 Wee, rebuilt like new and then some after collision with deer and mildly farkled.
Jstrom is offline
post #3 of 11 Old 07-23-2012, 05:59 PM
Flashmo's Avatar
This^.
Try it with a helper to balance the bike for you the first few times until you get the hang of it.
Leave the bike on the sidestand.
Remove extra weight if necessary (seat, side bags, top box)
Place the pads right around the Axle.
Push down on HF handle with right hand while standing the bike to verticle with left hand. Once the bike is vertical and touching both pads, if you keep pressure on the handle it will stay up.
Transfer left hand to HF handle, and lean all your weight into it, bike will come up.
It would be nice if they had a longer handle (longer lever), but they don't...
edit: remembering back...I put the rear wheel and sidestand each on a piece of 2x4 when I first got mine. Once I learned the technique, they were no longer necessary.
Flashmo is offline
post #4 of 11 Old 07-23-2012, 06:16 PM
bwringer's Avatar
Put spools on it -- the pads make things far more difficult.
That's what those 8mm threaded holes are for...
bwringer is offline
post #5 of 11 Old 07-23-2012, 10:07 PM
Never buy a bike you can't pick up. Or learn about hoists and mechanical advantage.
My Wee is a cinch to put on the center stand. I got the spools at Harbor freight for a few bucks too if you have that sort of lever arm.
post #6 of 11 Old 07-23-2012, 10:46 PM
The Harbor Freight stands are difficult because they don't have a handle. Get a PitBull and install spools. I know they aren't cheap, but they are a breeze to use and you will use it for years. I believe you should buy good stuff and make your life easier in the long run.
Oh and whatever stand you use, make sure the front wheel is straight.
Pit Bull Motorcycle Stands & Accessories: Spooled Rear Stand
Crotchety is offline
post #7 of 11 Old 07-24-2012, 07:56 AM
beewerks's Avatar
I have the HF model, and yeah, I can't get it up by myself either. I weigh 160lbs and always use a helper to keep the bike upright, and work the front brake for me. The Pitbull stands are super nice, but the HF stand was less than half the price easily.
2007 V-Strom 650
2005 Yamaha TW200--Sold
1981 Kawasaki KZ750
beewerks is offline
post #8 of 11 Old 07-24-2012, 08:15 AM
What good does half the price do you when it doesn't do what you want it to do? Spend the money once on a PitBull and be happy with it for years to come. My PitBull works flawlessly. I weigh 166 and I can easily put my Vee up with one hand and no help. I have been lured by HF's lower prices a couple of times too and I always regret buying their crappy to barely adequate products. On the other hand, whenever I have purchased quality stuff, I'm always glad I did everytime I use it. JMO.
post #9 of 11 Old 07-24-2012, 08:41 AM
garandman's Avatar
Woodcraft rocks. Made in USA. Stable and low lift effort.
garandman is offline
post #10 of 11 Old 07-24-2012, 01:38 PM
shortchaz's Avatar
I use one like this
Pit Bull Spooled Forward Handle Rear Stand - Street Bike - Motorcycle Superstore
I'm tall so that gives me a little more advantage but this stand lets me stand the bike up with my left arm and hold it steady from the bars and push the bike up with my right.
2005 DL1000
shortchaz is offline
