Anyone have valve check at 14,500 miles yet? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 11 Old 07-11-2012, 12:38 PM Thread Starter
Just wondering if anyone has had their valves checked after 14,500 miles yet and if so if they were in spec or not. I am at that point but have to travel for work and wondering if I need to get it checked before I leave or if it can wait. Thanks, Vinny
ultrarnr is offline
post #2 of 11 Old 07-11-2012, 12:41 PM
https://www.stromtrooper.com/informat...-had-done.html
post #3 of 11 Old 07-11-2012, 12:50 PM
I did my first one at 22000 and they were all within spec.
RichardD is offline
post #4 of 11 Old 07-11-2012, 01:20 PM
Scarlett Harlot's Avatar
Checked mine at 15,000 miles and all valves were in spec but 2 exhaust valves were on the tight end. Will check them again later this summer.
'05 GL1800A-The Banana Hammock
Target fixator extraordinaire.
Never underestimate the power of stupid people in large groups. ― George Carlin
Make the world safe for stupid people and you will end up with a world full of stupid people.
Scarlett Harlot is offline
post #5 of 11 Old 07-11-2012, 01:33 PM
21,000 for my first check. All valves were tight, but I ride the crap out of the bike- lots of hard acceleration and high rpm.
edit: I should note that I did swap the cams prior to checking the valves, so I don't know what the stock clearances were- just put the new cams in and checked the clearances.
GrayStrom44444 is offline
post #6 of 11 Old 07-11-2012, 02:26 PM
bassbronco_74's Avatar
checking the valves is fairly easy...just some dis-assembly required...
i checked mine at 14K miles and two exhausts were on the tight side and the rest were tight of the middle...but all still in spec...i left them alone for this summer as i needed the strom for commuting...but i plan on digging back into them this winter and adjusting all of them into the middle of spec and then leaving them...i only want to do it once...
DL650K7
XL1200N (Sold)
bassbronco_74 is offline
post #7 of 11 Old 07-12-2012, 08:56 AM
beewerks's Avatar
I had a shop check mine a month ago at 17,500 miles. The intake was in spec, but the exhaust was out. Can't remember which way though. I also tend to ride in the higher RPMs longer.
2007 V-Strom 650
2005 Yamaha TW200--Sold
1981 Kawasaki KZ750
beewerks is offline
post #8 of 11 Old 07-14-2012, 04:50 AM
DBuck12's Avatar
I'm curious about changing your camshafts. Do you have a Vee or a Wee? Which cams did you switch to? I believe SVs and TLs have a different grind than the DL.
Buck
K3 DL1000
K5 VN1600A
DBuck12 is offline
post #9 of 11 Old 07-14-2012, 09:55 AM
If you changed the cams for more power they would have more lift. It stands to reason the clearances would be tight.
post #10 of 11 Old 07-15-2012, 01:40 PM
perArdua's Avatar
After a swap of camshafts, your clearances can be anywhere, regardless of lift. You are measuring the clearance with the valves fully closed, at the cam base circle. This base circle can vary from one cam to another, even between some with the same designed lift or even with the same part number.
Checking your valve clearance right after changing the cam will tell you little about the clearance before the cam change. If the valves are still fully operational, still sealing well, at least you can surmise that the clearances likely weren't way too tight before the swap.
my $.02
Marc
Marc, rider of a black 2009 V-Strom 650A ABS
"To the Companion who knows how to go light and fare hard, who is friendly with the rain, and finds no road too long." William Blake in "Brown Waters and other Sketches", Malbaie, May, 1915.
perArdua is offline
