Beating the Heat - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 7 Old 07-10-2012, 03:50 PM Thread Starter
Dread7's Avatar
Beating the Heat
I was looking for ways, as I do each year, to beat the high heat. I found "Hog Coolers" and "Veskimo's" so apparently using ice and pumping ice water through a vest is becoming more popular but I'm not that into it.
Motorcycle Cooling Vest, Full & Half Face Helmets, DOT Helmet, Gloves, Heated Vest, Saddle Bags, Mohawks, Face Masks
Cool Vest for Heat Stress Relief, Motorcycle Cooling Vest: Veskimo Personal Cooling Systems
Of course we also have the vests that evaporate water which won't work well where I live due to high humidity.
I considered the neck rags but again high humidity and they don't work. Then I found "Black Ice". I'm considering ordering one of these to try it out. If it works I could get two and carry ice with one in the cooler charging all the time. Be awesome for working in the yard too.
Anyone use one of these?
Black Ice Personal Cooling System CCX-S
Formerly clovett but changed to my gaming name
2004 DL650 1998 DR650 1994 CB1000 1992 DR350
2004 Z400 1965 Norton 650 1984 Honda XL200
1975 Suzuki RM125 1972 Yamaha 100 enduro
1971 Honda CT90 1968 Honda Z50A
Dread7 is offline
post #2 of 7 Old 07-10-2012, 05:35 PM
Sentinel's Avatar
I don't even start to get really uncomfortable until it gets into the 90+ range, but above that I just try and limit my riding.
Sentinel is offline
post #3 of 7 Old 07-10-2012, 06:17 PM
jnor's Avatar
Looks interesting....I would rather ride in 30 degree temps than 90+ drgree. I can get warm with heated gear, but can't get cool.
15 DL1000
jnor is offline
post #4 of 7 Old 07-10-2012, 07:42 PM
I use a $6.00 neck tie that has water absorbing beads in it. Once you soak it in water for about 5 minutes the beads swell up and hold water for 8 hours or more. You the tie it around your neck and you have all day evaporative cooling. I used to do the same thing with a dollar store bandana, however I needed to re-soak the bandana at least every 45 minutes.
Cool Off Tie - Scarves and Masks - Clothing - Clothing :: Aerostich/RiderWearHouse Motorcycle Jackets, Suits, Clothing, & Gear
ghostrider66 is offline
post #5 of 7 Old 07-10-2012, 08:56 PM
Rick505's Avatar
Looks like the BlackIce unit has the chemical ice stuff you freeze:
Black Ice recharges in a freezer or fridge, but with a quick 20 min. recharge in ice water, the CCX-S gives you access to true 24/7 cooling. Just keep your spare pack in a cooler of ice water and swap out when needed.
If you can live with "powder Blue" it's $10 cheaper. Can't really tell any major difference between the two.
Rick505 is offline
post #6 of 7 Old 07-10-2012, 11:15 PM Thread Starter
Dread7's Avatar
The site is a little confusing but the difference of $10 isn't because it's different, you are correct. It's because the additional $10 gets you two cooling packs. The packs separate from the band allowing you to always have one pack cold to swap out. You can get either in 7 different colors.
If you dig through the information you will see what is actually inside is a type of mineral oil.
Dread7 is offline
post #7 of 7 Old 07-10-2012, 11:27 PM
Get a jacket, Vest sew some pockets in it and fill it with ice, Or buy the little ice packs you freeze for 1.95 Save a few hundred dollars,,,,
Mike
Iride is offline
