Atv high bar and steel brake line installation, any tips? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 4 Old 07-09-2012, 01:44 PM Thread Starter
domromer's Avatar
I've got a set of bars and a new double front brake line at home waiting to be installed. Any tips? The total package includes a 2" Rox riser, the high bars, and the new brake lines. Is there an order of operation that makes the most sense? Should I bleed and install the brakes while they are still on the old bars? What do you guys think? I'm trying to keep this to a minimum debacle.
Sent from my phone...there will be spelling errors!
If all you ever do is all you've ever done, then all you'll ever get is all you ever got.
domromer is offline
post #2 of 4 Old 07-09-2012, 04:34 PM
I'd install with the new bars and risers to get the brake line fittings all in the right location. I know there is is a tabs on the master cylinder the banjo fitting sits against as a stop, but still.
2003 V - ASV C5 Levers, Univ. Solex bars, grip heaters, ktm mirrors, c.stand, SW Mo Engine grds,Two Bros, PC3, Garmin, Givi 460, tank bag, F. Extenda, BackOff, Super Brace, Elka Shock, Race Tech Gold. AWD/Mr.Ed's Moto seat mod. Dumonde Tech Racing Oil, Spider grips, Contour.
2001 KTM LC4 farkled (sold)
awd505 is offline
post #3 of 4 Old 07-09-2012, 08:31 PM
CHINOTAKER's Avatar
I didn't
I didn't do the brake lines myself, but I did the ATV's bars and riser.
I would recommend to get the brake lines first and then the other 2. Also cut all the zip tides
Good luck
K9 ABS 650 BLACK
V-Strom: "The bulletproof machine"
[url]http://v-strom123456789.blogspot.com/[/url]
CHINOTAKER is offline
post #4 of 4 Old 07-09-2012, 08:55 PM Thread Starter
domromer's Avatar
Got it squared away, now I'm just trying to get slack on all the cables.
domromer is offline
