Help! Chain lube all over rotors - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 6 Old 07-07-2012, 07:01 PM Thread Starter
domromer's Avatar
So this morning I'm working on my truck and my 7 year old nephew is washing my bike. I'm not really paying attention until I hear an aerosol can. I get over there pretty quick and he is "cleaning my bike" with a can of dupont teflon I had left on the ground. He has coated the rear of the bike pretty well. He also to my dismay decided the metal wheels needed to be washed as well. He thoroughly sprayed down the rotors as well. I immediately grabbed a can of brake cleaner and sprayed the hell out of the rotors. I did this a few times. Then I washed down the entire bike and cleaned the rotors a few more times. I took it for a ride and initially the brakes had no bite. Then I went around the block and braked repeatedly and the brakes seemed to feel normal again. My question is are the pads shot or can they be cleaned with brake cleaner?
If all you ever do is all you've ever done, then all you'll ever get is all you ever got.
domromer is offline
post #2 of 6 Old 07-07-2012, 07:26 PM
chicago's Avatar
I've had the rear of my DR650 covered in oil twice from a failed countershaft seal. I did remove the pads and cleaned them with brake cleaner.
14 tooth for me
chicago is online now
post #3 of 6 Old 07-07-2012, 08:21 PM
I've cleaned pads w/ brake cleaner before and all was well. Should be no problem.
"The first five days after the weekend are always the hardest."[INDENT]-- My wife[/INDENT]
WiredDriver is offline
post #4 of 6 Old 07-08-2012, 01:00 AM
Brake cleaner is actually to clean grease off the metal parts. Anything that soaks into the friction material usually ruins the material. Take the pads out and wash them well in the cleaner. If there is some lube remaining on the pads, try lightly sanding them with fine sandpaper (I put the sandpaper on a flat surface and rub the pads across). If they don't clean up completely, junk them.
post #5 of 6 Old 07-08-2012, 07:07 AM
Makes me happy my boys are lazy
richw is offline
post #6 of 6 Old 07-09-2012, 09:52 AM
FlyFishJeff's Avatar
That stinks! Reminds me of the time that my 3-year-old daughter asked me if I liked the sticker on her shirt. It was my new license plate registration sticker that I'd left on the table! Those things don't come off without breaking apart (at least here in Ohio). Thankfully, a replacement sticker from the BMV costs less than the original.
2014 BMW R1200GS "Heidi"
2016 KTM 500 EXC Six Days "Kate"
FlyFishJeff is offline
