Replacement Ga Tank for dl1000 - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 3 Old 07-04-2012, 11:28 PM Thread Starter
Question Replacement Ga Tank for dl1000
Hi, new to forum---Need to replace damaged 2006 dl1000 gas tank--is the dl650 gas tank the same item or are they different? Thx
banacheck is offline
post #2 of 3 Old 07-04-2012, 11:36 PM
The both use the same fuel tank. However, there are two types. One vents through the cap and the other vents through a hose to a charcoal canister. It's best the get the same type or you have to play with it a bit. There is also the color match to consider.
post #3 of 3 Old 07-05-2012, 10:02 AM Thread Starter
Much Thanks
Thx fo the info
Tags
gas tank , parts , rebuild , replacement
