trailering with ramps - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 29 Old 06-21-2012, 09:14 PM Thread Starter
kiwi_outdoors's Avatar
figured I should try out the new-to-me ramps I bought last year
here are two photos
it was easy, I just needed a careful hand on the clutch-throttle combo so as to not stall the engine as I inched my way up, for coming down it was engine-off
each of the three ramps have a safety cable to hook them to trailer
center ramp is heavier as it takes the bikes load, with me on it
kiwi_outdoors is offline
post #2 of 29 Old 06-21-2012, 09:28 PM
No wheel chocks?
leclairk is offline
post #3 of 29 Old 06-21-2012, 09:48 PM
Do the ramps fit in the trailer?
Crotchety is offline
post #4 of 29 Old 06-21-2012, 10:20 PM Thread Starter
the ramps fold in half, so, yes, they could fit -
the ramps fold in half, so yes, they could fit - this session was a test of loading, thats all
post #5 of 29 Old 06-21-2012, 10:22 PM Thread Starter
re wheel chock
Originally Posted by leclairk View Post
No wheel chocks?
I have used temporary arrangements for a front wheel chock in the past with my EX250 (sold), but I am leaning to a removable steel wheel chock for the Wee, becasue the Wee is bigger and heavier
post #6 of 29 Old 06-22-2012, 12:53 AM
I'd feel better about walking the bike up the ramps...strong ramp on the right for the bike, two lighter ramps on the left to walk on.
post #7 of 29 Old 06-22-2012, 10:03 AM
doug44's Avatar
Exclamation
Dammer boy, excuses me but that trailer does not look long enough etc. My advice would be to buy a different trailer with a tilt/tip and forget this setup as it looks like this setup would be tail heavy when loaded with the Strom which is not a good idea and will cause w-e-a-v-e .......
Doug K9CRT
Decatur, IL
Member Of The Infamous Springfield Milers BMW Club
Yamaha Super Tenere 2013
DL 650 K11 (Black Wee)
DL 650 K9 (Orange Wee) traded
DL 1000 02 traded
Cage ** Honda S2000 Roadster**
doug44 is offline
post #8 of 29 Old 06-22-2012, 11:42 AM
Mudbutt's Avatar
They look like a bridge.
Mudbutt is offline
post #9 of 29 Old 06-22-2012, 11:43 AM
bbg.will's Avatar
+1000!!! Its harder to drop a bike with your feet planted on something firm... give it some gas, feather the clutch and walk that thing up...
His -[INDENT][/INDENT]'07 Wee-Strom - '07 Kawi KLX250s
Her's -[INDENT][/INDENT]'13 Genuine Buddy 170i Pamploma
bbg.will is offline
post #10 of 29 Old 06-22-2012, 12:17 PM
swoody126's Avatar
arched ramps
the arched ramps are a great addition to the rider who uses a trailer or pick up with a higher, off the ground, load surface
it helps in the avoidance of high centering, during the loading process, as you've shown in the above pictures
your WIDE ramp combination also aids the loader by providing a place to, either, walk the bike from either side or ride it up while paddling with both feet
when it comes to mounting things like wheel chocks and tie down rings in a utility style trailer, i've become a great fan of BED BOLTS
Truck Tie Downs | Removable Eye Bolts | BedBolts.com
BED BOLTS can be installed in a wooden floored trailer and pulled down flush so that when you aren't hauling your skooter, the eye bolts can be removed, without tools, to return your trailer to a flat floored hauling machine
for folks who haul their skoots in the bed of a pick up, the remaining BED BOLT HEADS are in the lower troughs of the corrugated bed design and that doesn't interfere with the use of the pick up bed, when the eye bolts are removed, again w/o tools
for just anchoring a chock or center rail, i just use a common 3/8" bolt to secure them, instead of the eye bolts that come with the bed bolts
your wide arched ramp should give you many glitch-less loadings & unloadings
shiny side up
Everyone crashes. Some get back on. Some don't. Some can't.
steve
'05 WEE (LRW)
'99 DR TREE FIDDY SEX
plus several BRAND X
swoody126 is offline
