Bike pump for a few PSI? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 16 Old 06-20-2012, 07:26 PM Thread Starter
Hey GUys,
Can you use a bike floor pump to put a few more PSI in the tires?
Thanks
squishystevenson is offline
post #2 of 16 Old 06-20-2012, 07:29 PM
chicago's Avatar
That's what I do.
14 tooth for me
chicago is offline
post #3 of 16 Old 06-20-2012, 07:55 PM
Me too.....
YellowHat is offline
post #4 of 16 Old 06-20-2012, 07:55 PM
flyingjib's Avatar
Likewise. I also do the car tires. Takes about 5 minutes each for 32psi. Gets the heart rate up :mrgreen:
Earl
2006 Red Wee Strom
1984 Honda VT500FT Ascot
flyingjib is offline
post #5 of 16 Old 06-20-2012, 10:33 PM
tiller4me's Avatar
Originally Posted by chicago View Post
That's what I do.
:iamwithstupid:
Goes with us when we go to enduros, too. Easier to pack verses an air tank.
79 GS1000S
97 TL1000S
2005 DRZ400
2005 KDX220R
2007 DLK
2009 KLR650
2007 FJR1300
2007 Honda XR650L
tiller4me is offline
post #6 of 16 Old 06-20-2012, 10:36 PM
Jarvis's Avatar
I carry a small hand pump to reinflate my tires after coming off of gravel or dirt roads if I am going to be on pavement for a bit.
2018 DL650XT - Nomad
2012 WR250R - Rowen
2003 KTM 450 EXC - Hulk
Jarvis is offline
post #7 of 16 Old 06-21-2012, 11:32 AM
Look for a bike pump that pumps on both the down and up strokes, as it pushes a lot more volume than others. Anything geared towards mountain bikes will do that.
I'd recommend the Topeak Joe Blow Floor pump. About $40 on Amazon.....maybe about $50 in a bike shop.
Marksam911 is offline
post #8 of 16 Old 06-21-2012, 11:55 AM
wingnut11's Avatar
One more here using a manual type bicycle pump. I use it for..... well adding a couple psi here or there. If it's more than 15 psi I'll use an air compressor. Nice way to get the ticker going in the morning when you have to add to both tires.
wingnut11 is offline
post #9 of 16 Old 06-21-2012, 11:59 AM
swoody126's Avatar
tyre pump
i also keep a 12 volt mini pump, wrapped in a towel under the seat, that plugs into my battery tender plug
twist the key, release the seat, unwrap the pump & plug it in
many of my friends have become quite dependent on it
it fits in a small sack & is about the size of a large orange, all wrapped up
if you're wondering about the size of some of the units on the mkt, just remove the nice plastic case they come in and you're set
the high end, dual action, bicycle pumps are also great solutions...
either way, keep a close eye on your pressure
good for tyre life & bike control
shiny side up
Everyone crashes. Some get back on. Some don't. Some can't.
steve
'05 WEE (LRW)
'99 DR TREE FIDDY SEX
plus several BRAND X
swoody126 is offline
post #10 of 16 Old 06-21-2012, 12:00 PM
Stoopy's Avatar
You can get away with putting bicycle air in your motorcycle tires, but I don't recommend it. I did this once before going out for a couple hours' ride on the weekend, and upon returning home and jumping off the bike, found that my riding gear had turned into a too-tightly-fitting spandex onesie with guady high-vis designs and sponsor logos all over it. All in all, it's a questionable (and potentially visually unappealing) type of "darkside" tire maintenance alternative.
Maybe just do this to get home in an emergency or if you want to pick and choose which traffic laws apply to you or not.
"Ignorance is a powerful tool if applied at the right time, even usually surpassing knowledge." - E.J. Potter
Stoopy is offline
