How do you adjust shifter? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 3 Old 10-22-2006, 08:43 PM Thread Starter
I have searched for the answer, as well as looked at the PDF of the manual. My KDX has no linkage, so moving that is a no-brainer. I'm not sure how to do it on the Wee, though.
I just installed the footpeg lowering kit, so I need to lower the shifter accordingly.
2006 V-Strom 650 (red)
2006 WR250F
drummer is offline
post #2 of 3 Old 10-22-2006, 09:19 PM Thread Starter
never mind...
I figured it out. Now, if there was an easy way to get the brake lever lower. I know Greywolf cut his pushrod, but I'm not much of a mechanic, so that scares me a bit. Maybe a project for this winter.
2006 WR250F
drummer is offline
post #3 of 3 Old 10-22-2006, 09:59 PM
I took the pushrod out to cut it. A pair of circlip priers is handy for that. It's important to turn the assembly upside down because it will leak brake fluid. If I had it to do again, I'd leave it in place to cut it. If somebody would post the pushrod diameter, I can make a sleeve.
