Air pump on petrol stations - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 17 Old 05-02-2012, 10:09 PM Thread Starter
CHINOTAKER's Avatar
Hello Fellow stromtroopers,
When I pump air into my sneakers in the petrol stations I notice that I have to bend the valve to make the hose fit. I think through the years it can cause a malfunction or air leaking.
Is there a solution for that?
like a L shape convertor or something like this?
any help is appreciated
K9 ABS 650 BLACK
V-Strom: "The bulletproof machine"
[url]http://v-strom123456789.blogspot.com/[/url]
CHINOTAKER is offline
post #2 of 17 Old 05-02-2012, 10:13 PM Thread Starter
CHINOTAKER's Avatar
I used to have the same problem with the tyre pressure gauge but got a L shaped one.
Is there in the market a device that can do both measure and be a convertor as well?
I don't trust the petrol station pump pressure gauge. Here in OZ we have the ones that you set up the psi and it does it automatically. I never get the same psi when I compare with the tyre pressure gauge I've got
K9 ABS 650 BLACK
post #3 of 17 Old 05-02-2012, 11:56 PM
teevee's Avatar
K&L Right Angle Valve Stem - Street Bike - Motorcycle Superstore
not sure of the size for the strom but i plan on putting them in during the next tire change.
'08 DR650, '07 DL1000
teevee is offline
post #4 of 17 Old 05-03-2012, 01:24 AM Thread Starter
CHINOTAKER's Avatar
thanks for that !
I just got new tyres but will consider next time.
maybe I am being paranoid and don't really need anything ? otherwise it will be for sale already
K9 ABS 650 BLACK
post #5 of 17 Old 05-03-2012, 02:02 AM
tiller4me's Avatar
Another choice:
90-degree Aluminum Valve Stems, * 11.3mm * (select color), PJ's Parts
79 GS1000S
97 TL1000S
2005 DRZ400
2005 KDX220R
2007 DLK
2009 KLR650
2007 FJR1300
2007 Honda XR650L
tiller4me is offline
post #6 of 17 Old 05-03-2012, 02:37 AM
Banned
DO NOT USE 90 degree valve stems!
They end up failing due to the tire's rotation interacting with their inertia (which is exacerbated by the extra weight); they fail in exactly the same way that bending your valve stem to fill the tire will cause it to fail.
The solution is to use the shortest valve stem you can fit on the tire.
The other and better solution is to carry a small (slime) compressor under your seat and fill the tire before you ride. The advantage to that is you're not pumping your tire full of water like you do at the petrol station.
SittingDuck is offline
post #7 of 17 Old 05-03-2012, 02:55 AM
tiller4me's Avatar
Got to disagree with you on this one. The link I posted is for a threaded base valve stem. These have been used on sportbikes capable of much higher speeds than a Vstrom with no failures reported in any forums they have been recommended in. Mine have gone through over 5 years of use on my TLS and still holding air, and it sees 125+mph regularly.
Your assessment might be accurate for the pull through the rim type rubber base ones, and I think you would probably be right. I wouldn't trust that type for longevity.
79 GS1000S
97 TL1000S
2005 DRZ400
2005 KDX220R
2007 DLK
2009 KLR650
2007 FJR1300
2007 Honda XR650L
post #8 of 17 Old 05-03-2012, 06:54 AM
p38arover's Avatar
One can buy a 90 deg adaptor that one fits to the existing valve stem just to inflate the tyres. One then removes it.
I have one in my kit.
here's a pic I found on the 'net:
Ron B. VK2OTC
2007 Yamaha XJR1300
RIP Bucko
1979-2008 - Riding on forever
p38arover is offline
post #9 of 17 Old 05-03-2012, 07:04 AM
DBuck12's Avatar
Not to be argumentative but the 90 valves were standard on my 1600 Vulcan. I've never had the first hint of a problem since 2005 when it was new.
Buck
K3 DL1000
K5 VN1600A
DBuck12 is offline
post #10 of 17 Old 05-03-2012, 07:20 AM
Work well, make sure you get the one piece ones.
The universe won't end and your wheel won't explode
Pete
PeteW is offline
