Who's bright idea putting flat screw for calipers? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 9 Old 05-02-2012, 06:31 PM Thread Starter
Location: Kind of live in bc, but back to Nomad. No home.
K wtf... tried heat, ice and vice grips on rear brake caliper screw. Anyone else manage to use the "flat" screwdriver to pull this screw out?? Mine is almost chewed at this point.
Sexyman is offline
post #2 of 9 Old 05-02-2012, 06:53 PM
Flashmo's Avatar
Are you talking about the little dust cover for the pad mounting pin? Should come right out.
Flashmo is offline
post #3 of 9 Old 05-02-2012, 06:58 PM
Made me wonder. I did a search for 'removal of rear caliper pin' and found a shit load of info about the pins and pad R&R.
I went to the garage and tried undoing mine..Made a little snap and came loose. I wouldn't use locktite on these assys. You might want to get them undone at a later date.
post #4 of 9 Old 05-02-2012, 07:33 PM Thread Starter
I looked at the front calipers. They have hex style nuts pinned through the pads. I'm starting to think someone broke the last and put this flat screw through.
Sexyman is offline
post #5 of 9 Old 05-02-2012, 10:11 PM
Kurgan's Avatar
Slow down...
That "screw" is just a cover, a cap. The actual bolt/pin is a hex head beneath.
Jim
Kurgan is offline
post #6 of 9 Old 05-03-2012, 03:03 PM Thread Starter
Ya got it... still dumb as hell.
Sexyman is offline
post #7 of 9 Old 05-03-2012, 04:24 PM
Manual impact screwdriver.
I try first by hand then if it looks like I'm gonna strip it, out comes Birtha. But on brake calipers I always use it the heat makes them stick
2003 DL1000, 2005 DRZ-400s, 1984 Trail 110
[SIZE="5"][B]Everything looks better from inside a motorcycle helmet![/B][/SIZE]:hurray:
jar3316 is offline
post #8 of 9 Old 05-03-2012, 05:48 PM
randyo's Avatar
I learnt about getting the hand impact out of the tool box on some things even if the condition of the fastener looked new and clean, like Volkswagen shroud screws on air cooled engines many many solar rotations ago, often just using it as a hand screwdriver just cause the hardened bit is always a good fit to the slot
RandyO
IBA# 9560
07 Strom 1k (8x,xxx miles)
99 SV650 (135,006 miles)
82 XV920R
A man with a gun is a citizen
www.gbhsurvey.com
randyo is offline
post #9 of 9 Old 05-03-2012, 09:26 PM
Kurgan's Avatar
I agree, absolutely. I'd rather have a rubber plug in that spot or just thread the whole damned thing like the front calipers.
Jim
Kurgan is offline
