Pc-8 wiring question - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 4 Old 05-01-2012, 12:01 PM Thread Starter
nobie381's Avatar
Hi all, I believe this belongs on the tech/maintenance forum but I can't seem to get there through the iPhone app. Anyway...
I have purchased the Eastern Beavers PC-8 fuse block and had a question on wiring.
In general I was thinking of the below setup so if I am wrong please let me know. Voltmeter will use 14g wiring and connect it using a 2amp fuse. Then I have two power outlets which will use 15amp fuses (this wiring came from Eastern Beaver so it should be gtg). My big issue is I wanted to connect my stebal air horn too. My question is will this be an issue? I was going to try to use the wires it came with from PWD which uses 14g wire but the fuse in that configuration is a 30amp fuse but a 20amp fuse is all the fuse box can handle. I looked up the horn and the spec say the horn absorbs 18amps so not sure if the 20 amp fuse will work. Or if I should leave the horn connected to the battery.
2011 SUZUKI DL650 V-Strom ABS/Pearl Mirage White
Farkles: Aprilia Tuono mirrors / Pat Walsh Design Super Brace / DL1000 Seat / Givi engine guards / RR Peg Lowering Kit / Madstad Bkt w/ OEM or Givi Shield / PL532 & E41nn / SW-Motech CenterStand / EB PC-8 - 2x power outlets - Datel Voltmeter - Stebel Horn with PWD setup - Digital Slim H4-3(9003) Bi-Xenon HID - 1157 LED Brake lights
Shiro Nakama Hachi [SIGPIC][/SIGPIC]
nobie381 is offline
post #2 of 4 Old 05-01-2012, 01:02 PM
Yes, horn relay to the battery.
14 for the voltmeter? Could be much smaller, but use anything you have.
post #3 of 4 Old 05-01-2012, 02:39 PM
A 20A fuse is fine for the Stebel. Many installations have used a 15A but that's a bit close to the 13A the horn can draw and some 15s have blown.
post #4 of 4 Old 05-01-2012, 02:44 PM
CanadianFZ6's Avatar
18g (if not 20g) is perfect for a Volt meter... they draw very little power...
2015 DL650AL5 in Blue
CanadianFZ6 is offline
