Do I change my chain or not? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 14 Old 04-24-2012, 10:53 PM Thread Starter
cwvet's Avatar
Hello group,
I have a 2008 DL 650 with approx. 19K on the chain, 15K of which are mine. My cousin and I are heading to Alaska in July on a 3 week trip. We should do about 7-8K on the trip. Should I change the chain prior to the trip or not? I am not sure how long a chain is expected to last. I do not routinely clean the chain but I do regularly lubricate it every 3-4 rides or daily on a long range trip. It seems in good shape.
Any other maintenance besides new tires and oil change before the trip?
Thanks for your responses.
DL 650 ABS 2008 Madstad, Rifle windscreen, Scott's stabilizer, Oxford heated grips, RR fork brace, Jessie's
WR 250F 2008
cwvet is offline
post #2 of 14 Old 04-25-2012, 12:52 AM
Flying Pig's Avatar
Check the condition of your brake pads and the brake fluid level for both front and rear.
Look at the adjustment marks on your bike. If your chain is running out of room on the swingarm (2-3 notches left or less), then just swap it out now. I've found in my limited experience that once a chain starts to stretch, it usually stretches faster than slower from there.
Also, take a look at your sprockets (remove the cover to check the front one). If the teeth are not uniform or are worn down, then there's a high probability that the chain is nearing the EOL too :beatnik:
Other than that, have fun, and bring your favorite cleaner to clean off bugs. They are usually easier to clean off when fresh rather than if you leave them there for a long time.... If you're camping, bring some rags. If you're staying at some hotels, just ask for rags. Hotels would much rather find you a rag than have you use their towels for bugs
[SIZE="1"]When was the last time you checked your tire pressure?[/SIZE]
Flying Pig is offline
post #3 of 14 Old 04-25-2012, 01:50 AM
ozart's Avatar
Where you're headed, I'd replace the chain and front sprocket.
ozart is offline
post #4 of 14 Old 04-25-2012, 01:53 AM
TwoShots's Avatar
You didn't say "is."
So yeah, replace it and the sprockets while you're at it.
[IMG]http://kolobwebstudio.com/myimages/strom_liquid_jesus.png[/IMG]
TwoShots is offline
post #5 of 14 Old 04-25-2012, 07:43 AM
Mud Puddle's Avatar
+1...I would change the chain and the sprocket as well.
09 "Wee"-Strom DL650 (Orange)
99 Harley-Davidson XL1200S
00 Bultaco
73 Bultaco Sherpa-T
Mud Puddle is offline
post #6 of 14 Old 04-25-2012, 07:45 AM
randyo's Avatar
trip to alaska , change it, and sprockets too
RandyO
IBA# 9560
07 Strom 1k (8x,xxx miles)
99 SV650 (135,006 miles)
82 XV920R
A man with a gun is a citizen
www.gbhsurvey.com
randyo is offline
post #7 of 14 Old 04-25-2012, 08:44 AM
Craig Jackman's Avatar
+1 on changing chain and sprockets.
'03 DL1000 - "The Vee"
Mod list - Oxford heated overgrips. Garmin GPS w/Aquabox RAM mount. Mirror extenders. Givi V35 saddlebags, engine guards, and Kappa top box. Adventure Tech fork brace, wheel spacer, sidestand foot, and peg lowering kit. Gafler braided front brake & clutch lines. K&N air filter. Pyramid Fenda Extenda. GO Cruise throttle lock. Touratech folding shift lever. Rad guard. GSXR 4 piston brakes with SV Racing brackets. Yosh timing cover. SW Motech center stand and crossbar. Eastern Beaver headlight relay. 12 O'Clock Labs Speedo DRD. Werks clutch basket. Corbin seat.
Craig Jackman is offline
post #8 of 14 Old 04-25-2012, 08:57 AM
Living the Stereotype
Stromin'Nroman's Avatar
Hey, if you don't change it, you'll have something fun to think about on long boring stretches of remote two-lane highway in grizzly country. Things like, "I hope the chain doesn't skip on that worn sprocket and get wadded up bad enough to crack the case and spew my crankcase oil all over the road. I knew I shoulda' changed 'em out, dammit"
I put 30,000 miles on my last chain and the front sprocket didn't look too bad. I've seen much worse. But why torture yourself with doubt on a trip where you're not likely to be able to coast into a Suzuki dealer's service bay at a moment's notice?
Change the chain and both sprockets and keep your head in the ride.
Stromin'Nroman NC28729, USA
Stromin'Nroman is offline
post #9 of 14 Old 04-25-2012, 09:20 AM
Scott E. Bonds's Avatar
I was thinking almost the exact same thing. And, I have pushed chains further....but why worry over it so far from home.
2007 Blue SuperVee 1000
2000 Red Honda XR 400r
Scott E. Bonds is offline
post #10 of 14 Old 04-25-2012, 10:12 AM
MikeB's Avatar
And it will take his mind off the fear of running out of gas.
2008 DL650A
2016 KTM 390 Duke
- Mark Twain, 1887
MikeB is offline
