16T Front Sprocket - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 13 Old 10-20-2006, 12:30 PM Thread Starter
A1A
16T Front Sprocket
I pulled the trigger and ordered a 16T front sprocket for my wee. I've been procrastinating for a while and reading the Reverendbikers thread helped in my decision making, Thanks Rev! :wink:
I'm still a little apprehensive and I do hope the low speed torque of the wee will still be there after this sprocket swap though. :roll:
But, on the highway the engine is a little to buzzy at 85 or so miles per hour and the sprocket change should help considerable. 8)
Cheers!
Richard #3125
Blue 05 DL650
Yellow 04 SV650N Scantily Clad
A1A is offline
post #2 of 13 Old 10-20-2006, 12:56 PM
Good screen name.
"BEACHFRONT AVENUE!!!!"
/offtopic vanilla icing
Wilken is offline
post #3 of 13 Old 10-20-2006, 02:09 PM
Reverendbiker's Avatar
Re: 16T Front Sprocket
Originally Posted by A1A
I pulled the trigger and ordered a 16T front sprocket for my wee. I've been procrastinating for a while and reading the Reverandbikers thread helped in my decision making, Thanks Rev! :wink:
Cheers!
Give us a report after you've done the swap!
jack <><
'07 DL650, "which may just be the most shockingly competent machine in the world today"--Cycle World
www.reverendbiker.com
Reverendbiker is offline
post #4 of 13 Old 10-20-2006, 03:42 PM Thread Starter
A1A
Originally Posted by Wilken
Good screen name.
Thanks! I needed something simple for a simple person. :lol:
Richard #3125
Blue 05 DL650
A1A is offline
post #5 of 13 Old 10-20-2006, 03:44 PM Thread Starter
A1A
Cheers!
Yes I will do that my friend.
Richard #3125
Blue 05 DL650
A1A is offline
post #6 of 13 Old 10-20-2006, 05:38 PM
I did the 16T swap at the beginning of this summer. About 300rpm lower on the freeway and little difference in acceleration. Maybe a bit better gas mileage, too.
Fourvalve is offline
post #7 of 13 Old 10-21-2006, 06:20 PM Thread Starter
A1A
Thanks my friend, that sounds very simular to what Reverendbiker stated.
Cheers!
Richard #3125
Blue 05 DL650
A1A is offline
post #8 of 13 Old 10-22-2006, 02:03 AM
Kawidad's Avatar
I did mine last year and like it very much. I never noticed any decrease in acceleration or power at all.
Kawidad
2007 DL1000K7
Kawidad is offline
post #9 of 13 Old 10-22-2006, 12:41 PM Thread Starter
A1A
I'm feeling a lot more comfortable now hearing everybodys positive responses regarding the 16T front sprocket swap. 8)
Cheers!
Richard #3125
Blue 05 DL650
A1A is offline
post #10 of 13 Old 10-28-2006, 02:32 PM Thread Starter
A1A
I can honestly say I like the switch from a 15t to the 16t front sprocket. My wee has plenty of punch in the city. When on the highway in 6th gear my cruising speed is between 5000 and 6000 rpm usually or approx. 70 to 80 mph. Which translates to lower engine rpm and better fuel mileage. For reference with the stock 15t I'd be turning 5500 to 6500 rpm for the same 70 to 80 mph speeds.
I can still run the engine down to below 2500 rpm in 6th gear and just twist the throttle to increase speed. One thing for sure when you have a 16t front sprocket . You will not have that urge to shift to a imaginary 7th gear due to buzzy revs in the 650 engine.
If I lived in the mountains I think I'd stick with the stock 15t - 47t sprockets of the wee strom. Maybe even go with a 15t - 49t.
Cheers!
Richard #3125
Blue 05 DL650
A1A is offline
