Genuine Suzuki accessories - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 9 Old 04-16-2012, 09:31 AM Thread Starter
Craig Jackman's Avatar
Got home from a ride to find that my bike wouldn't go up on the center stand. Took a minute to figure out why. So, do I find a good welder, or just replace? I've found the SW Mototech and Suzuki stands online at about the same price ($215-$225 ish).
'03 DL1000 - "The Vee"
Mod list - Oxford heated overgrips. Garmin GPS w/Aquabox RAM mount. Mirror extenders. Givi V35 saddlebags, engine guards, and Kappa top box. Adventure Tech fork brace, wheel spacer, sidestand foot, and peg lowering kit. Gafler braided front brake & clutch lines. K&N air filter. Pyramid Fenda Extenda. GO Cruise throttle lock. Touratech folding shift lever. Rad guard. GSXR 4 piston brakes with SV Racing brackets. Yosh timing cover. SW Motech center stand and crossbar. Eastern Beaver headlight relay. 12 O'Clock Labs Speedo DRD. Werks clutch basket. Corbin seat.
Craig Jackman is offline
post #2 of 9 Old 04-16-2012, 10:12 AM Thread Starter
Better - $120 at Murph's kits.
post #3 of 9 Old 04-16-2012, 10:54 AM
bassbronco_74's Avatar
Good call! There are a couple threads floating around about the Murphs Kit one. I just installed mine about a month ago and love it so far. Some complain about some of the welds. Mine was so so, but the structural ones were fine IMO. So I didn't bother sending it back for a prettier one. Once on the bike you can't see them anyways! Great product for a great price!
DL650K7
XL1200N (Sold)
bassbronco_74 is offline
post #4 of 9 Old 04-16-2012, 08:10 PM
dao270's Avatar
Check into the hepco Becker
I just took a Hepco Becker off my 06 dl1000 cause I sold the bike. Do some research and see if it will fit. If it does you can have it for $125 plus shipping. Send me a PM or email.
dao270 is offline
post #5 of 9 Old 04-17-2012, 08:37 AM Thread Starter
Thanks for the offer, good price too. I went with the Murph's Kits center stand, thinking that to pay someone to straighten the old one up, weld up the breaks and cracks and weld on some reenforcement steel is going to be $100 anyway. If you've seen my bike you will understand when I say I don't care about ugly welds on something below the engine.
Put your stand in the For Sale section. Someone will pick it up at that price.
post #6 of 9 Old 04-19-2012, 08:18 AM
Definitely buy a new one and don't try welding the old one. For such a low price item that will hold your bike up, it's worth getting new...
jeff137 is offline
post #7 of 9 Old 04-20-2012, 04:09 AM
1VStromNC's Avatar
Hepco & Becker center stand
Here is a thought,
Spend a few bucks more and order the Hepco & Becker center stand.
A nice very high quality center stand which I just installed a few weeks back.
Went on in less than 25 minutes, taking my time.
Ordered it from Chad at Adventuremoto. Perfect.
Saw a post of another trooper who ordered a Murphs c/s. It arrived missing parts and had some rust issues? And missing parts?? What the??
Here is the post, scroll down to the bottom of the page. I am glad I paid a little extra for the Hepco and Becker c/s.
https://www.stromtrooper.com/dl650-20...650-wee-6.html
2015 DL 650 Wee
2015 R1200 BMW ADV
"Ride as if your life depends on it"
1VStromNC is offline
post #8 of 9 Old 04-30-2012, 09:09 AM Thread Starter
Got the Murph's stand in, and it is a duplicate of the Suzuki. The welds on mine are fine, though the bolts feel a little light duty. Since the Suzuki was coming off, reused the heavier bolts where appropriate. Initial install was atrociously stiff, so took it all apart and used MUCH more grease everywhere around the pivots and bushings. Still not perfect, but 70% better. Now have to nudge the stand up a bit after use, much like I had to do with the Suzuki one. Got to reexperience the joy of the springs. Should have watched the video for the string method, instead used a long screwdriver to leverage the springs onto the pin. I'm happy with it.
post #9 of 9 Old 04-30-2012, 04:26 PM
Murph's Kit Stand
I've got the Murph's Kit stand and it seems to be strong enough. The thing that you may have to correct is that there may be weld material on the bracket(s) that gets in the way of the stand when you prop the bike up on it. You won't know until you have it mounted and try to use it and find the bike teetering and threatening to come back down. If this happens, you'll need to remove the brackets and file flat the portion of the weld that gets in the way of the stand where it should stop against the bracket(s).
I had to file both brackets on mine.
Inconvenient, yes, but still worth the savings for me.
2004 DL650
1968 Triumph T100C
Dnepr MT11 (Russian Sidecar Rig)
TimF is offline
