Tire balancing - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 28 Old 04-11-2012, 11:31 PM Thread Starter
Tire balancing
What do you guys do for balancing your own tires at home?
2011 DL 650
07 525 EXC
07 200XC
jeff408 is offline
post #2 of 28 Old 04-11-2012, 11:41 PM
Jarvis's Avatar
Dynabeads so far...
There is one issue with them hanging up in the valve stem and causing a leak. You have to remove the valve stem, clean it out, and re-inflate the tire. I haven't had it happen to me yet but I have read about it in a couple of posts.
2018 DL650XT - Nomad
2012 WR250R - Rowen
2003 KTM 450 EXC - Hulk
Jarvis is offline
post #3 of 28 Old 04-12-2012, 12:01 AM
tiller4me's Avatar
Works for me........
Motorcycle Wheel Balancer w/ Stand
79 GS1000S
97 TL1000S
2005 DRZ400
2005 KDX220R
2007 DLK
2009 KLR650
2007 FJR1300
2007 Honda XR650L
tiller4me is offline
post #4 of 28 Old 04-12-2012, 12:18 AM Thread Starter
Originally Posted by tiller4me View Post
Perfect. I have lots of HF stuff. This is now on my list.
Thank you, Jeff
2011 DL 650
07 525 EXC
07 200XC
jeff408 is offline
post #5 of 28 Old 04-12-2012, 01:10 AM
darcy's Avatar
tire balancing
I just get the shop to balance the rim once, and then mount my own tires at home.No matter how many tires I put on the balanced rim they always work out fine, Todays tires are pretty good. Have never gone more than 200km pr hour on them so not sure if would hold up to higher speeds using this method.My BMW rt rear rim needed 2 ounces,front 1 ounce.
darcy is offline
post #6 of 28 Old 04-12-2012, 06:21 AM
I use the axle between to jack stands, ladders, saw horses or whatever will keep it high enough.
BornAgain is offline
post #7 of 28 Old 04-12-2012, 06:41 AM
I static balance using the axle rolling on a pair of short pieces of angle iron. The axle is rolling on the edge of the angle, so the friction from any of the bearings is eliminated. I also use stick-on weights from J C Whitney.
'12 Guzzi Stelvio NTX
'09 DL650 ABS (Sold)
Chuck in Indiana is offline
post #8 of 28 Old 04-12-2012, 07:28 AM
Stock axle and bearings on saw horses
Tape weights temporarily held by masking tape
Slap to break static friction
40 years of happy motoring
richw is offline
post #9 of 28 Old 04-12-2012, 07:42 AM
I use Ride-On.
It works for me
2008 DL650 Yellow
coachchuck is offline
post #10 of 28 Old 04-12-2012, 08:45 AM
knotzilla's Avatar
I welded a stand out of metal. I also have attached 2 skateboard bearings on each end which the axle sits on. This allows more movement than the wheel bearing itself I think, I'II post pictures when I get home tonight
knotzilla is offline
