Shifting gets worse after installing peg lowering kit? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 19 Old 04-11-2012, 02:06 PM Thread Starter
domromer's Avatar
Has anyone had this happened? I installed the peg lowering. Kit and now the shiffting seems a lot more notchy. I've adjusted the angle of the shifter arm a few times and it doesn't seem to make a difference.
Any ideas?
Dom
If all you ever do is all you've ever done, then all you'll ever get is all you ever got.
domromer is offline
post #2 of 19 Old 04-11-2012, 02:09 PM
henerythe8th's Avatar
I just installed Richland Ricks peg lowering kit last night, and I think that the shifting is smoother, easier.
BTW - my connecting linkage is perpendicular to the arm on the shift shaft, best mechanical advantage...
2011 MG Stelvio
henerythe8th is offline
post #3 of 19 Old 04-11-2012, 02:09 PM
vegashotwheeler's Avatar
Send a message via AIM to vegashotwheeler
My input would be to post a pic of the finished project so maybe we can spot something your not.
Mike
2007 Blue DL650 V-Strom - running out of farkle's to do so bought the VEE
2006 SILVER DL1000 - Running out of Farkles also!!!
2017 EX300 Kawasaki Ninja
Las Vegas, NV
vegashotwheeler is offline
post #4 of 19 Old 04-11-2012, 02:18 PM Thread Starter
domromer's Avatar
Would you mind posting a pic of your set up.
domromer is offline
post #5 of 19 Old 04-11-2012, 02:19 PM Thread Starter
domromer's Avatar
Mike
Ill get a photo up this afternoon when I get home.
domromer is offline
post #6 of 19 Old 04-11-2012, 02:30 PM
Try lubing the joints under the rubber covers as well as the main arm pivot with chain lube. The pivot is best disassembled and greased. The repositioning does require taking the arm off the shaft and moving it one notch. That reduces the mechanical advantage a little.
post #7 of 19 Old 04-11-2012, 02:48 PM Thread Starter
domromer's Avatar
Do you mean remove the arm and apply grease to the splined shaft?
domromer is offline
post #8 of 19 Old 04-11-2012, 03:41 PM
No.
He means the shaft that the shift lever pivots on near the footpeg and the portions under the rubber caps on the intermediate piece between the shift shaft and the lever.
Lubing the splined portion will do nothing but catch dirt...
2011 MG Stelvio
post #9 of 19 Old 04-11-2012, 04:12 PM
Chain lube under rubber covers #28 and #31. Grease on the round, not threaded portion of #33 that carries #30 though chain lube helps if you don't remove #30. It helps if #29 and #27 are at right angles to each other at rest but that usually isn't possible with lowered pegs.
post #10 of 19 Old 04-11-2012, 04:12 PM
tmcgee's Avatar
It can definitely be adjusted and lubricated for smooth action. After you move the lever on the shaft, use the fine adjuster (29 on Pat's image) to dial it in.
tmcgee is offline
