Throttle cable lenght - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 6 Old 04-11-2012, 10:59 AM Thread Starter
Does anyone know what is throttle cable length ?
Im looking for 1'' longer then stock.
Universal throttle cable can be found in 47''.
Thought, i'll ask before remove it from the bike.
Thanks
[COLOR="Yellow"]DL650K8[/COLOR]
GIVI Engine guards, OEM Hand Guards, GIVI Windshield, RichlandRick's Fork Brace, RichlandRick's Auxillary Shelf, Eastern Beaver Lo Beam Cut Adaptor, Blue Sea, SW-Motech Skid Plate, SW-Motech Quick Release Rack, Trax Panniers, Suzuki Gel Seat, 12V Powerlet, Symtec Heated Grips, Digital Voltmeter
PLRider is offline
post #2 of 6 Old 04-11-2012, 05:08 PM
I know this has to do with the riser situation you have, so I must ask, have you thought about rerouting the throttle cables behind the forks instead of thru them?
stromdog is offline
post #3 of 6 Old 04-11-2012, 05:13 PM
This is what I did when I added my risers to my 2006 DL650 (obviously) w/o ABS. No need for longer cable on the non - abs versions. I don't know if rerouting would work on an ABS model.
Banks C[FONT=Comic Sans MS]:crying:[/FONT]
2006 DL650 Current Engine 15,625 Prior engine 67,426 when chain came off and bent valves
2005 Yamaha FJR1300A 68,000 miles and counting
Banks C is offline
post #4 of 6 Old 04-12-2012, 09:29 AM Thread Starter
Sure did think about it, but didnt do it yet. Just got the air box off.
I will try today. When would be easier to disconnect the cable by throttle body or grip ?
thanks
PLRider is offline
post #5 of 6 Old 04-12-2012, 10:14 AM
Since you are already at the trottle body that would be the easiest now. Just mark the position so you can align it back to how you found it.
I am going to lower my triple tree when I do mine so I am thinking about removing the top triple and routing any tight cables over the triple and thru the risers for more clearance.
stromdog is offline
post #6 of 6 Old 04-12-2012, 10:41 AM Thread Starter
Im thinking that i would go from the grip, because i never worked with throttle body before. I did look up at shop manual but there is no description on how to remove throttle cables at throttle body, therefore, im not really sure what you mean but marking position of them...
PLRider is offline
