Wee won't start - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 5 Old 04-06-2012, 05:45 AM Thread Starter
nottarb's Avatar
Wee won't start
OK before I go tearing things apart figure I'd post for some thoughts first.
I put ROX risers on the bike and there didn't seem to be any tension other than move the brake line a bit but when I went to go for the test ride I turned the key I heard the pump and when I hit the starter button NOTHING happened ----first thought was "OH S**t" what did I do now and then rightfully said step away from the bike stop & look & think first --- hence here I am asking before I leap
Pappy
nottarb is offline
post #2 of 5 Old 04-06-2012, 07:51 AM
sakebato's Avatar
Did you check the clutch cancel switch? There is a little plug on the clutch lever that comes off easy.
K7 Wee ( Stormy ) [SIGPIC][/SIGPIC] Matt
sakebato is offline
post #3 of 5 Old 04-06-2012, 07:54 AM
CanadianFZ6's Avatar
Clutch handlebar switch probably unplugged itself in the process or moving things about....
2015 DL650AL5 in Blue
CanadianFZ6 is offline
post #4 of 5 Old 04-06-2012, 09:25 AM
Flying Pig's Avatar
Yup. I'm also betting it's that switch. I re-installed my hand guards and was ready to take off for work last week and got the fuel pump to prime, but nothing from the starter no matter if the clutch was pulled in and kickstand was up or down.
Was almost ready to give up and take a... car ... then ran back to the bike and sure enough that little black connector was dangling around
Popped it back on and the Strom fired right up
[SIZE="1"]When was the last time you checked your tire pressure?[/SIZE]
Flying Pig is offline
post #5 of 5 Old 04-07-2012, 08:11 PM Thread Starter
nottarb's Avatar
Thanks guys you are right the plug was loose I pulled it off and replugged and the Wee started right off just in time for some great weather
I've learned again!! and it's better to ask questions first and then tear things apart
Pappy
nottarb is offline
