OEM Heated Grips problem - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 14 Old 04-04-2012, 06:06 AM Thread Starter
I had the Suzuki heated grips installed on my '12 DL650. On the high setting I get a little heat in a narrow horizontal strip at the front of the left grip and basically nothing in the right grip. Are the OEM heated grips basically junk, or might I have defective grips or maybe instalation error? If an installation error is there something specific I should have the shop look at? I'm not a wizard with electrons and I'm not sure the shop mechanic is either.
mattinri is offline
post #2 of 14 Old 04-04-2012, 08:39 AM
randyo's Avatar
the oem grip are known to not provide heat around the entire grip, but they do have heat on the portions you actually grip while riding, I haven't had problems with mine.
'12 did the dealer install them? I'd make an appointment to get it checked out should be a warranty item
RandyO
IBA# 9560
07 Strom 1k (8x,xxx miles)
99 SV650 (135,006 miles)
82 XV920R
A man with a gun is a citizen
www.gbhsurvey.com
randyo is offline
post #3 of 14 Old 03-30-2014, 02:03 AM
Suzuki OEM grips on my 2012 Vstrom 650 are worthless too
I bought the Suzuki OEM heated grips, which were installed before I picked up my 2012 Vstrom 650. On high, the grips get just slightly warm. I bought my bike at the Suzuki dealer in Santa Fe New Mexico. They basically screwed up everything they touched and I will never have them work on my bike again. This makes me wonder if the OEM heated grips are garbage, or did the garbage dealership screw up the installation. Any advice appreciated.
GergB is offline
post #4 of 14 Old 03-30-2014, 02:10 AM
OEM heated grips are notoriously problematic. I don't know about your dealer.
post #5 of 14 Old 03-30-2014, 03:34 PM
I bought the OEM heated grips when I bought the bike (for a pretty good discount). However, the dealer didn't want to install them so I did it myself and they work well. Sounds like your dealer messed up! Better go back and ask about it.....
kback is offline
post #6 of 14 Old 03-31-2014, 12:49 AM
bobfrey101's Avatar
It's bad grips, unless they rewired something, installing them is a no brainer, you plug it in to the oem plug that it fits into, not only is it extremely hard to mess up but I can't think of a way they could hook it to only partially work, it just wouldn't heat up at all.
With that said, my controller went out and after replacing it the left grip was only warm right at the edge, replaced the grip and it works Fine. From what I read when diagnosing mine, the oem grips are known for problems.
bobfrey101 is offline
post #7 of 14 Old 03-31-2014, 10:00 AM
I've got 10 year old Oxfords on my Wee and those suckers work great...if you can't get the dealer to rectify the stock grip problem.
The Oxfords are far better than any of the factory heated grips I've had on my Beemers.
post #8 of 14 Old 08-29-2014, 11:21 AM
I have OEM grips now, installed by previous owner. If I want to put the Oxfords on the bike, can I still use all the OEM electrical (switch, wiring, etc.) and just mate the new grips with the existing electrical system?
Would be cleaner and easier, unless the switch shows problems also....
2002 DL1000
Madstad and Screen, Enduro Skidplate, Barkbusters, Hyperlites (front and rear), 17/43 sprockets, Reemis Exhaust, PCIII, Speedo DRD, OEM Heated Grips, Fork Brace and Lowered Pegs (AdventureTech), Givi top and side cases, Givi Engine Guard
maz_norcal is offline
post #9 of 14 Old 08-29-2014, 08:24 PM
Bugzy's Avatar
Likely all the connectors would be different between Oxford and stockers. The Oxford controller is made for that product and easy to install. Oxford is cheap too. Under $100. Get a set and be happy.
Bugzy is offline
post #10 of 14 Old 08-30-2014, 01:50 PM
WeeTN's Avatar
Oxford heated grips
After reading this post, I have just ordered a set of Oxford heated grips.
Happy about the price and a third of the price for OEM! Thanks to all!!
WeeTN is offline
