Tool Tube - Vent Hole or No Vent Hole? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 15 Old 04-01-2012, 05:02 PM Thread Starter
Prime's Avatar
Made one of those nice homemade tool tubes out of PVC tubing and got it mounted nicely. Looks like all the other tubes people make, but after installing it I got to thinking... ... should this thing have a small vent hole drilled into it or not? The tube seems to be completely watertight/waterproof the way it is and I'd imagine the hot weather is going to make the inside expand and whatnot. Also, would it be smart to keep my Dupont Oil spray can inside it?
Vent Hole: Yes or No?
"If everyone demanded peace instead of another television set, then there'd be peace" - John Lennon
"Every gun that is made, every warship launched, every rocket fired, signifies in the final sense, a theft,
from those who hunger and are not fed, from those who are cold and not clothed" - Dwight D. Eisenhower
Prime is offline
post #2 of 15 Old 04-01-2012, 05:13 PM
Evolving Curmudgeon
kick's Avatar
No vent hole in mine but I don't keep an aerosol can in it either. You're probably fine.
'07 WEE-HAAAA! Blue, loaded & sweet
I'll know where I'm supposed to be when I get there.
kick is offline
post #3 of 15 Old 04-01-2012, 07:49 PM
What kind of cap is on the open end?? Vent hole probably not required if the seal is not super-tight........???
www.easternvstromrally.com
mark444 is offline
post #4 of 15 Old 04-01-2012, 08:28 PM
bassbronco_74's Avatar
I would put a small drain/vent hole in the lowest part/corner. That way it's easier to get your lid on and off, it will vent when the air inside expands in the summer heat, and if you ever get a leak or get condensation inside it will be able to drain.
My .02
DL650K7
XL1200N (Sold)
bassbronco_74 is offline
post #5 of 15 Old 04-01-2012, 08:29 PM
No vent hole in mine, been carrying spray chain lube in Florida heat with no issues. I doubt your mounting holes are air tight anyway.
07 Wee
79 GS 850 G
callmelenny is offline
post #6 of 15 Old 04-02-2012, 09:03 AM
You worry too much - ride and have fun.
sweetcreek is offline
post #7 of 15 Old 04-02-2012, 09:17 AM
Living the Stereotype
Stromin'Nroman's Avatar
I think the only thing you for which you might want ventilation would be condensation.
Do you plan on filling it with expensive Cuban cigars or some other humidistatically sensitive cargo?
Stromin'Nroman NC28729, USA
Stromin'Nroman is offline
post #8 of 15 Old 04-02-2012, 09:59 AM
superslomo's Avatar
I don't have a vent hole, and mine seems to stay condensation free, and doesn't pop off or violently explode or whatnot. Don't overthink it
"Never run out of real estate, traction and ideas at the same time." - Mario Andretti
superslomo is offline
post #9 of 15 Old 04-02-2012, 05:32 PM
cdmarsh's Avatar
No vent hole in mine, and I carry chain lube.
cdmarsh is offline
post #10 of 15 Old 04-02-2012, 07:21 PM Thread Starter
Prime's Avatar
Okay... no vent hole.
Thread over.
Thanks for the feedback.
Prime is offline
