Givi case durability? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 11 Old 04-01-2012, 04:41 PM Thread Starter
TekNinja81's Avatar
Hey folks, quick question.
I'm sure nobody ever *wants* to find out, but I'm wondering if anyone here has had a tipover/crash with Givi hardcases on, and how they held up if so. I'm curious because I've always heard the Pelican cases can take a real beating, and online motovloggers such as halfthrottle have shown/proven this. I've thought of switching to Pelican cases as my Givi bags are a little rough (previous owner most likely dumped the bike at least once) but only if it would make any sense to do so.
Am also considering coating the outer shells with some sort of spray-on solution (maybe truck bed liner?) to improve the look/durability, if that would work.
TekNinja81 is offline
post #2 of 11 Old 04-01-2012, 04:57 PM
kiwi_outdoors's Avatar
my little box came off because my rack came off!!
my little top box box came off because my home-built rack came off!!
and they both got dragged and bounced along the city street - becasue my extra tail light wires stayed intact
the cas3e is a bit scratched but works perfectly
kiwi_outdoors is offline
post #3 of 11 Old 04-01-2012, 07:11 PM
Location: Kind of live in bc, but back to Nomad. No home.
Wink
Uh... High speed wobble 120km, will put a grinded hole in bag, but bag still worked, just put a garbage bag over to keep rain out. They function like motorcycle guards. If you drop bike on it's side the bags stop the fall with no scratchs on them. I make sure I have them on for off roading, no possibility of getting trapped with bike on your leg and no damage to bike.
I had top bag fall off due to the mount(It had loosened previously, when a dumb broad pulled out infront of me and I went into her b-piller), 140km grind on it and tail light cover disappeared but bag still functional. Fortunately had spot device running in bag, found it 33km away at some guys house. Make sure for the top mount, it's mounted through where the rubber cover should be.(chuck rubber cover) Totally worth every penny.
Sexyman is offline
post #4 of 11 Old 04-01-2012, 07:27 PM
I had a tank slapper at triple digits. The bike looked like somebody went all over it with a belt sander. One E36 bag got asphalt sanded enough that some grains got inside. The bags flew home filled with my belongings along with me and my cast. I replaced the covers and they were like new.
post #5 of 11 Old 04-01-2012, 07:38 PM
chicago's Avatar
My e21's have protected the bike in 0 mph tip overs. I think they are pretty tough.
14 tooth for me
chicago is offline
post #6 of 11 Old 04-01-2012, 07:41 PM
DougInKY's Avatar
Send a message via AIM to DougInKY Send a message via Skype™ to DougInKY
I have Givi E41 Keyless bags. Had a lowside last summer. Roughed up the lower part of the bag on the down side and scuffed the paint on my keyless door. Locks still work, bag is still watertight. I put a sticker over the scuffed paint and still have and use the bag.
2007 Wee-Strom (*SOLD*)
2009 Suzuki Burgman 650 Executive
1980 Honda Express (my toy!)
DougInKY is offline
post #7 of 11 Old 04-01-2012, 07:42 PM
domromer's Avatar
My e45s survived a few low speed off road crashes. The bike suffered bent bars, a broken shift lever, and a broken brake lever and the givis just had a few scuffs that I could have probably sanded out.
If all you ever do is all you've ever done, then all you'll ever get is all you ever got.
domromer is offline
post #8 of 11 Old 04-03-2012, 11:36 PM
Send a message via MSN to BikerTrash
I changed lanes onto a toyota Sienna minivan last summer and my left side bag rubbed from the sliding door to the tail light. (misjudged her speed she was doing like 85 in a 65) did almost 2000 dollars worth of damage to the van, just a small scuff on my bag and the mount on the left side is pushed about an inch in compaired to the right. Several years ago also dropped it at parking lot speeds and only a slight scuff. same bag.
the bags are the Givi Keyless. My bike is at the dealer right now getting a tuneup or I would take better pictures of it.
File Type: jpg 5If5W45M73M63Le3I4c3tf4c0990103e912ef.jpg (31.5 KB, 13 views)
File Type: jpg 5N85G55K53k73K13H8c3tb859b00b61471a2f.jpg (43.7 KB, 9 views)
'02 V-Strom
Givi: E41 sidebags, E52 topbag,Crashbars.
Alaska Leather: Sheepskin Buttpad
Progrip: Cheep grips.
Garmin: Etrex Legend (the blue one) GPS with handlebar mount.
Avon: Distanzia's
BikerTrash is offline
post #9 of 11 Old 04-03-2012, 11:50 PM
LoneStrom's Avatar
My E46 has almost 60,000 miles on it and my 2 E36's have about 40,000 on them and still work great.The 36's have been over a couple of times at low speed and only have small scratches.
Sent from my Motorcycle iPhone app
1990 Yamaha XT350
2012 Honda NC700X BDR express......
1994 GS500..DORA THE PURPLE EXPLORA
LoneStrom is offline
post #10 of 11 Old 04-04-2012, 01:19 AM Thread Starter
TekNinja81's Avatar
Glad to see the positive responses; sounds like the Givi's can take more of a beating than I would have expected.
I do plan to learn to ride on gravel/dirt roads to an extent this year, so perhaps I'll keep the sidebags on rather than off... ;P That'll be another post soon enough... how to handle myself on dirt & gravel...
