How to separate front brake rotors from carriers? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 10 Old 03-31-2012, 01:26 PM Thread Starter
Question How to separate front brake rotors from carriers?
I would like to put my front rotors on a Blanchard grinder, as I have with rotors from other bikes, in order to remove a slight warp and any residue.
In order to have a nice flat piece of metal (the rotor) which can be placed on a Blanchard grinder, I need to remove the rotor from the carrier. The rotors attach with some kind of round buttons that don't appear to be removeable.
Can the rotors be separated from the carriers, and then re-attached? How?
Thanks for your advice.
2008 DL650 ABS
rakad is offline
post #2 of 10 Old 03-31-2012, 01:34 PM
https://tpoparts.com/cat093/index.ph...product_id=225
Corse Dynamics Brake Rotor Floater Button - YouTube
post #3 of 10 Old 01-30-2017, 05:35 PM
larolco's Avatar
Resurrecting an old but relevant thread here.
I have an otherwise perfectly good front brake rotor on my Vee that has lost the wave washers that hold the buttons tight. In a short period of time, the rotor has developed a disturbing amount of rotational play (not just side-to-side) which has resulted in some "grabby" braking and unpredictable feel.
After researching a way to replace these buttons, I have found no solution for the Vee - only BMWs and Ducatis. It pains me (and my wallet) to toss away a good rotor. It has hardly any wear on it other than the buttons, and perhaps the carrier where it has worn against the buttons.
In the meantime, I have mounted an old, almost worn out rotor while I think about what to do.
If I could replace the buttons, I'd be a happy camper.
Any ideas?
Or failing that, if anyone's got one kicking around, I suppose I could use a used rotor...
DRZ400SK17
larolco is offline
post #4 of 10 Old 01-30-2017, 11:30 PM
Bugzy's Avatar
Try this?
https://www.tpoparts.com/cat093/inde...product_id=225
Here is another
http://motowheels.com/i-7579497-cors...or-button.html
Bugzy is offline
post #5 of 10 Old 01-31-2017, 01:43 PM
larolco's Avatar
These both appear to be Ducati/Brembo specific. It doesn't look like they would work for the Vee. Has anyone attempted a full float conversion on OEM Suzuki rotors?
DRZ400SK17
larolco is offline
post #6 of 10 Old 01-31-2017, 04:31 PM
Bugzy's Avatar
Maybe try this before you grind your rotors down?
Bugzy is offline
post #7 of 10 Old 02-05-2017, 01:32 AM
larolco's Avatar
$400 CDN for a new OEM rotor. Fuuuuuuuuuuudddge.
DRZ400SK17
larolco is offline
post #8 of 10 Old 02-05-2017, 02:34 AM
Bugzy is offline
post #9 of 10 Old 02-05-2017, 05:13 AM
strominateacup's Avatar
Yeah, but you only need two of them!
There are holes in the sky where the rain gets in,
and the holes are very small, that's why rain is thin.
Spike Milligan.
strominateacup is offline
post #10 of 10 Old 02-06-2017, 04:11 PM
larolco's Avatar
Just one, actually. The other rotor is fine.
If I was replacing both, I'd probably go after-market.
DRZ400SK17
larolco is offline
