Sonic Springs question - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 30 Old 03-30-2012, 09:30 PM Thread Starter
domromer's Avatar
I've decided that i want to turn my Wee into mostly road touring machine. I've already got bags, a centerstand, a touring windshield, rox risers, and 12v pwer supplies.. Now I've been thinking of ways to make the bike more comfortable. I'm currently using the stock seat with a seat of bead riders, but only have about an hour of riding before I start having to shift around, So I've been looking for a used Corbin or Sargent seat. My next thoughts were suspension. I'm pretty heavy at 280 and my wife rides with me 90% of the time and she is 130.
So I imagine the bike is woefully under suspended for our combined weight. I've heard good things about sonic and I've been talking with them via email about the correct springs. My question to you guys would the springs improve the bikes overall comfort? I'm not a performance rider by any means. I take it easy and mostly look at the scenery so a mod that is going to make a big difference while scraping a knee is not really something I need. I'm thinking of a sasquatch rebuild for the rear as the current ride is pretty harsh, but that will wait until the rainy cold month of january. Where as the new springs I can put in before I go on a big Florida ride next month. So what are your thoughts? Would the springs improve the bikes overall comfort?
Dom
If all you ever do is all you've ever done, then all you'll ever get is all you ever got.
domromer is offline
post #2 of 30 Old 03-30-2012, 10:03 PM
Easy...
.90 Sonic springs with 12 wt fork oil.
Done.
You are welcome.
Shooter is offline
post #3 of 30 Old 03-30-2012, 10:07 PM Thread Starter
domromer's Avatar
Rich's recommendation was 1.00 with 15wt.
domromer is offline
post #4 of 30 Old 03-30-2012, 10:16 PM
garandman's Avatar
I have 1.0's and I weigh less than you and ride solo.
You're going to need a much heavier spring in the back as well. Whether you have the stocker resprung or get a better shock depends on your budget.
The other change that folks make on the DL650 is to put in Intiminators or Racetech cartridges to improve the performance over bumps.
garandman is offline
post #5 of 30 Old 03-30-2012, 11:45 PM
bwringer's Avatar
Depends on your definition of comfort -- the bike will definitely handle better, meaning less effort and tension for you. The biggest thing you notice right away is less brake dive.
Don't wait on the rear shock -- get it rebuilt pronto, if not sooner. That will make a huge difference in handling, you won't bottom out over bumps, it will stop wallowing, and the bike will be FAR more pleasant to ride.
You may also want to replace the noodly stock handlebar with something stiffer -- I found that the stock handlebar's incessant flapping was extremely tiresome. A set of MSR ATV bars took care of that for around $25.
bwringer is offline
post #6 of 30 Old 03-31-2012, 08:58 AM
Kurgan's Avatar
EDIT: First figures were for a Vee, not a Wee
Stock springs up front are .65's and and an 8.2 in back which would barely be adequate for a 125 pound rider.
For 280 you'd need 1.10's up front and a 15.5 spring in back.
For 280 + 130 you need 1.3's up front and a 17.4 spring in back.
I've never seen 1.3's for Vstrom springs. Highest is 1.2's which would be for roughly a 350 pound rider. Rear spring, they've got 16.1's, 17.8's and even 19.6's.
Is the wife really on the bike with you 9 out of every 10 rides? If so, I'd think about setting it up for 350 pound load on average. 1.1's or 1.2's up front and the 16.1 out back.
Either way it's going to be loads better than what you're working with now.
With that higher load on your bike, I hope you've also beefed up the brakes with at least stainless lines and HH compound pads like from Galfer. I'd also flush the brake fluid every 10k miles or once a year.
Jim
Kurgan is offline
post #7 of 30 Old 03-31-2012, 09:24 AM
teevee's Avatar
simple answer is to call jay @ suspensions by sasquatch. he is an expert.
'08 DR650, '07 DL1000
teevee is offline
post #8 of 30 Old 03-31-2012, 11:17 AM
+1
You might be able to pick up a used shock, maybe one that is worn out and cheap, get that rebuilt by Jay, then sell your surplus shock. Yes, Jay at Sasquatch is a suspension expert, and so is Rich at Sonic.
post #9 of 30 Old 03-31-2012, 11:21 AM
I'm 275 with gear solo only and they recommended 0.95 springs. I'm not a performance rider. Made breaking less exciting and less squirrley in turns. Comfort is not better or worse. Just different. Also better in cross winds. Major improvement.
2009 DL650
Stromburger is offline
post #10 of 30 Old 03-31-2012, 07:30 PM
I do not know how to calculate the springs and oil..... I do know Rich's advice and hence the Sonic Springs has been the second best (after the Russel Day Long Seat) aftermarket improvement to my Wee. Bottoming out on pot holes or even dips on the interstate was an issue before, let alone brake dive, and I weigh only 150# plus gear.
I haven't had work on the rear shock yet...... that's the next item
kangarooman is offline
