c-41, c-11, replace cmp sensor, still c-11 - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 2 Old 03-29-2012, 12:05 AM Thread Starter
k2 dl1000, 34,000, restoring younger brothers bike, fuel relay was jumped, air cleaner upside down, kemo meds were probable cause, secondaries removed, was getting c-28 till I rotated secondary shaft, greywolf hope this catches your attension. Found that a piece of rg-6 coax tv cable makes a great cable probe, pointed on one end looped on the other, clips on volt meter wont slip.
roosted is offline
post #2 of 2 Old 03-29-2012, 01:27 AM
A c11 occurs when the signal does not reach ECM for more than 3 sec. after receiving the starter signal. A bad connection between the CMPS and the ECM can cause that. Also, besides the wiring, electrical coupler and CMPS itself, the intake cam pin the CMPS senses can be the culprit. I don't have any real hands on experience with the DL1000 and the DL650 doesn't have a CMPS. My go to guy for stuff like this is John Weldon, Johnofchar at V-Strom Riders International Group
