are steel braided brake lines worth the money? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 20 Old 03-27-2012, 08:27 PM Thread Starter
Lonney's Avatar
Hello V people,
I have an 11 wee abs and i have installed bar risers and would like put higher bars which looks like i need longer clutch and brake cables.Will steel braided brake lines improve brake performance with the abs.
Thanks
Lonney
Lonney is offline
post #2 of 20 Old 03-27-2012, 08:42 PM
It depends on the individual perception. They may improve feel, but that's about it. Feel is important though.
post #3 of 20 Old 03-27-2012, 08:56 PM
my buddy just bought an 011 wee w abs and was under the assumption he couldnt put risers only on without a new brake line.. is that not true??
superman is offline
post #4 of 20 Old 03-27-2012, 09:07 PM
RockyMtnScotsman's Avatar
braided lines do improve the feel but IMO you get more bang for the buck with better pads
2008 DL650 Matte Black
2006 Yamaha WR450F
1973 Moto Guzzi El Dorado
"America is at that awkward stage. It's too late to work within the system, but too early to shoot the bastards."
--Claire Wolfe
RockyMtnScotsman is offline
post #5 of 20 Old 03-27-2012, 09:19 PM Thread Starter
Lonney's Avatar
brake lines
I believe it was a 3/4 riser.
Lonney is offline
post #6 of 20 Old 03-27-2012, 09:24 PM
Voltar's Avatar
If I had to replace brake lines I would go with braided, but I would not spend the money just to 'farkle up'.
Voltar is offline
post #7 of 20 Old 03-27-2012, 09:36 PM Thread Starter
Lonney's Avatar
brake lines
Im really happy with the brakes i wouldnt change them if i didnt have to.THANKS
Lonney is offline
post #8 of 20 Old 03-27-2012, 09:54 PM
CHIA's Avatar
Yup, a set of HH pads will give you way more stopping oomph than braided lines, assuming your lines are not worn, and need replacing, which is doubtful for a 2011.
Better yet, do the SV Racing caliper mod, coupled with a set of HH's......it's like a new bike.
CHIA is offline
post #9 of 20 Old 03-27-2012, 09:55 PM
Thumbs up break lines
I have done them on several bikes both street and dirt and I feel like they give a much better break feel. They made a huge difference on an older HD I think the original owner never changed break fluid so I think they softened up the rubber ones. A vacume pump makes it much quicker to bleed new lines.
Good Luck
BoilermanNH is offline
post #10 of 20 Old 03-27-2012, 10:09 PM Thread Starter
Lonney's Avatar
brake lines
I have only put steel lines on a quad which made a huge difference but i dont wanna waiste money theres alot of other things my wee could use.Like bigger bars a set of those slick mirrors for starters.
Lonney is offline
