E52 install...Went smooth except for............... - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 18 Old 10-13-2006, 12:04 AM Thread Starter
With your help, I decieded on a Givi E52 topcase w/brake lights.
Easy to install, lots of room and looks great on my dl650k6.
Have a couple questions about the brake light harness that I couldn't find with the search, and the mounting base(givi) came with no instructions ?
It was pretty obvious where to punch out the plastic and snap in the harness end. No problem.
But where do I go from there ? (BTW, I'm electrically challenged).
I found the color coding here, but..... 1.)what is the best way to run the wires to the vstrom wiring behind the tool kit ?
And when I get them routed,..... 2.)what wires do I hook the blue and black wires from the harness to ?
They included two blue connectors with the kit, but I'm not sure how to use them.
I'm sure it's pretty simple to a lot of you, but I'm at an impass here.
Any help would be greatly appreciated.
Thanks,
Jim
LongRider is offline
post #2 of 18 Old 10-13-2006, 08:17 AM
Reverendbiker's Avatar
Re: E52 install...Went smooth except for...............
Thanks,
Jim
I've just posted a review of this process on my web site. Look it over--it should be self-explanatory. If you need more info on using the Scotch-Lok wire taps let me know.
http://www.reverendbiker.com/vstrom/givilight.htm
jack <><
'07 DL650, "which may just be the most shockingly competent machine in the world today"--Cycle World
Reverendbiker is offline
post #3 of 18 Old 10-13-2006, 10:50 AM Thread Starter
Hi Reverend,
I think even I can follow those directions.
BTW, nice web site and helpfull information.
I'm sure I'm not the only one who appreciates it.
God speed,
Jim
post #4 of 18 Old 10-13-2006, 10:57 AM
V-Tom's Avatar
When I did the kit for my E52 I spent a bit of time overthinking it.
I ran the wire it in the gap on the right side where the heat shield mounts. I had concerns that doing the route straight to the seat might put pressure onthe wire when people sit in the back. I did not want to drill hoes or cut the part like Reverand did as I suspect that ridge diverts water from getting into the under-seat area. I was able to hookup the connectors to the tailights by undoing one of the bulbs. The only change I did from the kit was to mount a quick-disconnect inlne (I read about doing so elsewhere... it wasn't my idea.)
..Tom
My Opinion:
Vee or V= DL1000 before 2014
Vee3 or V3 = DL1050 2020 to?
My Stroms:
SMIDSY detailed report.
V-Tom is offline
post #5 of 18 Old 10-13-2006, 11:33 AM Thread Starter
Thanks Tom,
I think I'm going to drill a small hole and then use some rubber cement or silicone to seal it. I do ride in the rain.
I'll look your method over when I get a chance to look at it this evening. Just hard for me to picture it without it starring me in the face.
Gives me some options and that's great.
Blue Sky's,
Jim
post #6 of 18 Old 10-14-2006, 02:12 AM Thread Starter
OK........I must be dim witted.
Last night I installed the E52 topcase.
This evening I installed Kouba lowering links, raised the forks 3/4", installed new windscreen on my madstad brackets, installed hand guards and SW-Motech barbacks and risers.
No problems on any of these.
Saved the brakelight wiring till last. After reading the Reverends instructions, I figuered it would be a 15 minute job.
Here's the dim witted part.
I can't get the gosh darn bulbs out of their sockets.
I turned them c-clkwise, I pushed them in and turned, I tried turning them clkwise, I did a jig and whistled Dixie.
I took it to my cousin's house and let him have a try.
Alas, to no avail.
WHAT am I doing wrong???
If there is a secret incantation, would someone PLEASE let me know what it is!!!
Yours truly,
Dim-witted Jim
post #7 of 18 Old 10-14-2006, 09:28 AM
V-Tom's Avatar
No help; but on mine the one on the right side of the bike turned okay, I never did get the other one loose.
..Tom
My Opinion:
My Stroms:
V-Tom is offline
post #8 of 18 Old 10-14-2006, 09:41 AM
Vordak's Avatar
Location: Eastern Ontario, Canada, Earth, Solar System.
Stand on one foot, jump up and down, rub your belly and turn the socket C-clockwise with your free hand.
Think happy thoughts too.
V.
8)
Never Argue with an idiot, first he'll bring you down to his level, then he'll beat you with experience...
1986 FZX750R Fazer-Should've never sold it!
1986 BMW K75-Old smoker! Good bike. Sold.
2003 DL 1000 Bumble Bee, farkled! Sold.
2006 Honda Goldwing Navi AL.
Vordak is offline
post #9 of 18 Old 10-14-2006, 09:53 AM
Vordak's got the key--you're just not holding your mouth right. :wink:
You're on the right track--just press in slightly on the bulb holder and twist counter-clockwise. Pull the one on the right (brake) side of the bike--it has more slack in the wires, and you'll need all you can get.
jack <><
post #10 of 18 Old 10-15-2006, 01:17 AM
blue (+) to white clable with black line
black (-) to black cable with white line.
lights will be like third brake light in cars
bye
NEGRO_NEGRO is offline
