bzzzzzzzzzzzzz what the heck is that vibration? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 15 Old 10-03-2006, 03:06 AM Thread Starter
cavehamster's Avatar
Send a message via AIM to cavehamster
Hi all,
I've developed a vibration on my DL1000K6. It starts to come on around 3400 RPM to 3500 RPM. I have 4600 miles on it (it's a month and a half old).
I have the Pat Walsh crash bars, of which you might recall that I recently had the right one snap a tab at the top. Before that happened, I had been noticing a buzz around 3200RPM, but this was coming from the insanely cheap pegs I had put on the bars. I welded the tab back as a temp fix, and this changed nothing. The buzzing pegs were driving me insane, so I took them off. The buzzing only got worse.
Pat sent me a new right hand bar, and I swapped it out, and the buzz went from a low frequency one that felt like it was under the bike to one that feels like it is the plastic up higher, and it shifted from 3200RPM to 3500. (pegs are still off).
Now, apparently I do have a dent in the skid plate, so I am going to take the whole setup off tomorrow and see what happens, but this is driving me nuts. I hooked up my TBS gauge today on a whim and noticed I'm a couple of inches off, maybe this is the cause? My home made gauge is 10 foot of 1/4 clear hosing with ATF as the fluid. If the skid plate removal makes it go away I'll beat that sucker back flat and see what happens. I got some rubber undercoat today that I am thinking of spraying on the skid plate to maybe help out, but I dunno.
I get the vibe at any road speed, any gear, but only at that RPM.
Anyone else fix a problem like this? :x
cavehamster is offline
post #2 of 15 Old 10-03-2006, 03:33 AM
Tige's Avatar
Send a message via Yahoo to Tige
The first thing I thought of when reading the subject of your post was - windscreen has come loose and is buzzing. Although, for me on the Wee, this usually happens around 5000-6500 RPM. The fix is quick - just torque down the bolts.
After reading your post though - sounds like you have much larger issues. Did you bash the skid-plate and crash bars or something?
Cheers.
Tige
Tige is offline
post #3 of 15 Old 10-03-2006, 04:15 AM Thread Starter
Well, I took the whole crashbar and skid plate off and went for a ride, and.... no vibes.
So, that's good news. Bad news is I gotta make it not vibe with the stuff back on. The skid plate is a little bashed, but not hugely bad:
This bash apparently happened when I was attempting to get myself out of some soft sand recently, but I was in the moment and didn't even realize it.
Looks like the power coat is peeling a little due to the proximity of the exhaust. I'm gonna try flattening it back out and seeing what happens, maybe spray the underside of it with the undercoating stuff. :wink:
Anyway, I'll post some updates.
Thanks.
post #4 of 15 Old 10-03-2006, 07:28 PM
VtSTROM-K5's Avatar
Send a message via Yahoo to VtSTROM-K5
cavehampster, looking at the photo of the plate assy. Why does it look like a connection tab was broken off at the top of the notched area??? :?
is this how the plate looks new? :shock: It would seem to me that this open
area would act as a low quality "Tuning fork " and that the top of that area
should be reinforced Or if possible bridged. just an idea ...
as I don't know the position that its mounting relates too I offer the following
2014 V2 DL 1000 25 miles and Onward
IF I only Rode in Good weather..
I WOULDN'T get to Ride in Vermont.at ALL!
we have 2 types of roads in Vermont, Unpaved roads and decaying back to .............Unpaved roads..
2005 DL1000 98,547 miles and continuing in the hands of it's new owner
VtSTROM-K5 is offline
post #5 of 15 Old 10-03-2006, 07:34 PM Thread Starter
Haha I like your drawing.
If you notice, there is a spot on each side of that area that has a broken off bit... here is what it looked like before i took it off:
That used to be straight across, but i guess the combo of the whack and sitting on the clamp has broken it. I took it off entirely. I'm debating patching it back kind of in the manner you drew out there.
Right now, I have hammered the skid plate back out, and am waiting for the 3M undercoating to dry. I figured it was worth a shot. Regardless, the constant stream of dirt from rainy roads has started sand blasting the power coat down the middle on the bottom of the skid plate, so it could stand a coating anyway. We'll see how it turns out.
post #6 of 15 Old 10-03-2006, 08:17 PM
VtSTROM-K5's Avatar
OK that explains the rough edges ... the undercoat will dry to a tack surface
If that doesnt do what you wanted it to Try the brush/rollon bedliner material . its avail. in 1 qt. size to do tailgates and such from napa
I'm not artistically inclined & can't afford photoshop......jack
post #7 of 15 Old 10-03-2006, 08:29 PM
I have photoshop cs. Ill send you a copy if you like.
Vinny is offline
post #8 of 15 Old 10-03-2006, 09:31 PM Thread Starter
Well, I haven't taken a picture yet, but I think it came out looking pretty good. My only concern at this point is that the exhaust is gonna be close to the pan, so I hope it doesn't do something dumb like catch fire :shock:
Being the geek that I am, I took an infrared thermometer and a blow torch, sprayed some of the undercoat on concrete, and heated it up. It looks like it starts to really dry out and turn white around 650F, and if I stick the torch up close, it will briefly flash (but that's above 1000F). Running the bike in the garage, I see that coming out of the header it gets around 800F, and upwards of 600F near the area that the plate is going to be close too. Hmmmm... maybe this wasn't the best idea, hah. The skid plate will be as close as a 1/4 inch from the pipe, so maybe that is enough room.
I think I'm gonna put on a little exhaust wrap in that area and see how it goes.
Wheee! :roll:
post #9 of 15 Old 10-06-2006, 12:04 AM
VtSTROM-K5's Avatar
cavehamster I was curious as to the outcome of the project as I didn't see a topic that started " Smokin hot DL1000 for sale "
So I assume ( Yeah I know the inference of the word :twisted: ) that everything is good to go as far as the radiant heat issue . but what about the vibrations?? :?
post #10 of 15 Old 10-06-2006, 12:09 AM Thread Starter
Being the lazy guy I am I haven't completed the project yet. I had to run down to Albuquerque on Wednesday so I just took the bike with no skid plate/bars. This afternoon I was going to give it a shot, but, well, I haven't yet. Although, bear with me, I'll probably go do it in a few here... maybe...
