Q-Self adj. clock #2 - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 9 Old 06-22-2011, 09:49 AM Thread Starter
Checked and cleaned all connections & Di ele greased all connections. Tested charging system & is charging well. Just had the battery load tested with these results. Voltage 12.66 measured 319 Cold Cranking Amps temp 76 Results Good battery. The clock still self adj to 1 AM.
Any Ideas ??
Run with the big dogs or stay on the porch
STOC 1905
IBA 28154
2011 White Wee under construction
05 Wee @ 50 K ( Gone @ 56 K Loved that bike)
02 1800 Wing @ 83K
Home just outside of NYC & THE YANKEES RULE
ST114ME is offline
post #2 of 9 Old 06-22-2011, 09:56 AM
Next would be the connections between the battery and the clock. The large connector under the rubber cover in the fairing and the connection to the instrument package itself are the usual suspects.
post #3 of 9 Old 06-22-2011, 11:18 AM Thread Starter
Any chance that it's the ignition switch
STOC 1905
IBA 28154
02 1800 Wing @ 83K
ST114ME is offline
post #4 of 9 Old 06-22-2011, 11:28 AM Thread Starter
The connector you mentioned I have already cleaned & greased that one.
Bill
STOC 1905
IBA 28154
02 1800 Wing @ 83K
ST114ME is offline
post #5 of 9 Old 06-22-2011, 11:44 AM
The clock is independent of the ignition switch. I would connect a voltmeter to check the red/white wire for voltage when cranking. I'm not sure what the cutoff point is where the clock resets but I imagine you should see something like 11.9V. Compare the reading to one across the battery when cranking. If the battery voltage is higher than R/W to ground, there is a marginal connection. It it's about the same and below ~11.9V, the battery may have passed but isn't doing a good enough job. If voltages are okay, suspect the connection at the instruments.
post #6 of 9 Old 06-24-2011, 11:43 AM Thread Starter
Well, everything that you have suggested has been completed. I am suspect of the stater solenoid as it now has a delay when the stater button is pushed. I have called my 3 Suzuki dealers in the area and as usual they don't have one.
Jeeze these dealers drive me nuts. Plenty of chain lube & plexus they have. I swear I believe the parts room is a break area with a coffee pot and a table. They walk into the room & walk back out to say we can order it see you in 10 days.
I also have removed every ground on the bike cleaned & greased & reinstall. I am scratching my head on this one.
Bill
STOC 1905
IBA 28154
02 1800 Wing @ 83K
ST114ME is offline
post #7 of 9 Old 06-24-2011, 12:09 PM
I still think the battery is the most likely problem. Try attaching jumper cables to a car battery. If it still resets the clock on starting, you'll know it's something else.
post #8 of 9 Old 06-24-2011, 04:24 PM Thread Starter
Ok I reviewed every step I took along this strange trip & I got the bike to have a complete non intermittent failure. Then the wire wiggling exercise began. Sure enough the connector in the fairing with the rubber boot. With a really close look I saw a slight ting of brown. On the black wire. Pulled it & then connected it with a crush connector & walla fixed.
Thank you for your patience GW
Bill Kane
STOC 1905
IBA 28154
02 1800 Wing @ 83K
ST114ME is offline
post #9 of 9 Old 06-24-2011, 06:49 PM
It must have been a black/white wire. That's the ground wire for everything in the fairing. Get a headlight relay kit from Eastern Beaver or Adventure Motostuff or do an HID light conversion that comes with a relay. That will take the headlight draw off the little contacts and connectors and you'll never have problems with them again.
