How to vaporize a stock front tire..... - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 36 Old 06-20-2011, 12:34 AM Thread Starter
Ex- moderator
813 kms at 120-140km/hr will reduce the tread to 1/16"....hope I make it home, I still have 800kms to go...maybe I should try slowing down...
Why Motorcycles? Because Golf, Soccer, Football and Baseball only require One Ball
CollingsBob is offline
post #2 of 36 Old 06-20-2011, 12:47 AM
bwringer's Avatar
That's not all that fast... are you also running the front tire at half the recommended pressure?
bwringer is offline
post #3 of 36 Old 06-20-2011, 06:26 AM
Are you sure that's not 8130Km?
I have 12,000Km on my front and regularly do 120 indicated. (110 actual) on a Vee.
Sounds very sus to me.
Cheers
Graham
2010 S10
GrahamD is offline
post #4 of 36 Old 06-20-2011, 07:53 AM
Evolving Curmudgeon
kick's Avatar
Low pressure was my 1st thought too.
'07 WEE-HAAAA! Blue, loaded & sweet
I'll know where I'm supposed to be when I get there.
kick is offline
post #5 of 36 Old 06-20-2011, 08:00 AM
Send a message via MSN to cezariomaia
Changed mine at 20000 km. Rear was changed at 15777 km. Mostly road use at 110/140 km/h two up + baggage. I'm 95 kg and wife 75 kg. (Strom 1000)
cezariomaia is offline
post #6 of 36 Old 06-20-2011, 08:27 AM Thread Starter
Ex- moderator
Pressure was checked before I left-but I will double check it before leaving this am 36/40 if I recall correctly...,will check manual to be sure- Thanks
post #7 of 36 Old 06-20-2011, 09:03 AM
Are your brake rotors glowing ?
richw is offline
post #8 of 36 Old 06-20-2011, 10:14 AM
randyo's Avatar
I would check yer pressure guage
RandyO
IBA# 9560
07 Strom 1k (8x,xxx miles)
99 SV650 (135,006 miles)
82 XV920R
A man with a gun is a citizen
www.gbhsurvey.com
randyo is offline
post #9 of 36 Old 06-20-2011, 11:15 AM
Banned
I commute at much higher speed than that, and my front would have lasted a good 20,000km, but I replaced it at 16 or so... I have 14,000km on my second front (battlewing) and it still looks new.
It's definitely not a speed issue, but a temperature issue.
Even low air pressure wouldn't wear it that fast (?)
Was the tire brand new and you rode for 800 or so kms in one stretch?
If so, it's your fault: new tires need to be heat-cycled to achieve their maximum grip and longevity; warm it up, cool it down, repeat 3 or times. (I'm surprised at how few people (tire dealers included) know about that.
SittingDuck is offline
post #10 of 36 Old 06-20-2011, 11:44 AM
randyo's Avatar
apparently none of the manufacturers know about heat cycling either for street tires
can't find one mention on any of the major tire manufacturers websites
RandyO
IBA# 9560
82 XV920R
www.gbhsurvey.com
randyo is offline
